Little Shake at Idle... what is it?
When my car is at idle at a stop sign or light, i feel a little shake in the engine, its not very major but i feel like a tug when sitting. So i did a full fluid flush out, oil change, changed spark plugs, had my exhaust pipes checked for leaks, checked the air intake box, everything seems to be in order. But it still shakes at idle. Anyone have any idea what could be causing this?
Can you tell if its the actual motor having a rough idle? May need a throttle body cleaning or plugs
Try popping the hood and start the car, see if it jumps alot. Rev it a few times, it should be pretty firm. If it moves around more than an inch than mounts is probably what it is.
Dennzo
12-06-11 04:49 PM
97-SC300
01-27-11 09:18 AM
