IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Tein flex installation
Old 12-31-10, 04:06 PM
rayy117
rayy117's Avatar
Default Tein flex installation
I put on some tein flexes and it makes a clunking noise... Was i suppose to put on the stock upper mount piece(thin metal piece) thats on the stock one? The first picture.... please help me out THANKS IN ADVANCE
Old 12-31-10, 05:17 PM
TOPSECRTIS
TOPSECRTIS's Avatar
It has been a long time since I did mine but I don't think that piece goes on the new ones. Did you make sure everything is tight? Does it only make noise when you hit bumps? Did you buy them new?
Old 12-31-10, 06:20 PM
rayy117
rayy117's Avatar
the guy i bought the suspension put about 6800 miles on it... so technically, it was brand new... Everything is tight and it only makes clunks when i hit small bumps but when i go over speedbumps, it doesnt make that noise... I put the damping thing to the softest and it stopped making the clunking noise when i hit bumps... Does that mean its not on there correctly?
Old 03-04-11, 11:23 AM
rayy117
rayy117's Avatar
no more suggestions?
Old 03-04-11, 08:09 PM
candyblue
candyblue's Avatar
sounds like one may possibly be blown out... unfortunately you cant always trust peoples judgment call on how long a used part has been installed. If it puts an extra bit of $$$ in their pocket, they'll tell you everything you want to hear.
Does it kinda rattle/clunk or just a straight clunk??
Oh and no you don't use that factory shim plate.
Old 03-04-11, 08:26 PM
plus1choi
plus1choi's Avatar
^ what he said. one may be blown if its just clunking, make sure all top bolts are tightened.
Flex's should already have tophats, you should not have to transfer anything from your OEM suspension. it should be a direct swap in and out.
Old 03-04-11, 10:31 PM
rayy117
rayy117's Avatar
I see, It just CLUNKS when i hit small cracks or pot holes but when i go over speed bumps, it doesnt clunk and when i drive on freshly paved road, it rides like a dream and still has its stiffness if i take turns...
Old 03-05-11, 12:02 AM
anotherLS
anotherLS's Avatar
did u check the top middle nut for the shock piston..sometimes that gets loose i usually use blue loctite on that nut
Old 03-05-11, 07:41 AM
TOPSECRTIS
TOPSECRTIS's Avatar
It would be really hard to help you without hearing the noise. I would just jack up each wheel, check that the top bolts are tight, and all your suspension parts are tight as well. Then like ^^^ said, made sure all 3 locking rings are tight. Some noise can be expected from after market suspension but a clunking noise sounds like something is wrong.
Old 03-05-11, 10:46 AM
rayy117
rayy117's Avatar
i used an impact gun on the tophat because i did some research and everyone said too tighten the nut on the top... still makes noise, ill try to record the sound
I8ABMR
Suspension and Brakes
10-22-10 11:13 AM
testing
10-21-08 08:25 AM
Scott1258
04-06-07 05:56 AM
kapdori
09-22-05 12:42 PM
Quick Reply: Tein flex installation
