IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Camshaft sprocket question about my 01 IS
Old 12-16-10, 06:46 AM
01_IS_4U
01_IS_4U's Avatar
Default Camshaft sprocket question about my 01 IS
I need to replace my camshaft seals since they are leaking and was wondering about the beefy sprocket that I assume is for the VVTI. Is there anything special when taking that one off or something to be careful about? I have taking sprockets off before and I just zap off the bolt and remove it but that one side looks like it might be a little more complicated. Any help would be appreciated. Need it done asap since it is leaking oil everywhere. Also, anyone know where to get a GOOD but cheap on price timing belt kit? That possibly includes the belt, tensioner, roller, water pump, ect? Thanks!
Old 12-16-10, 09:46 AM
baadhabit
baadhabit's Avatar
ive read that the vvti sproket (gear) is tricky to remove. if done incorrectly you can really be in deep trouble. i've never done this myself but there is some talk of this on the my.is forum
in regards to a timeing belt you can just get a Toyota belt.
Old 12-23-10, 11:41 AM
Agent0024
Agent0024's Avatar
If it is anything like the 2GS then you'll need a 14mm hex to take the first bolt out to get access to the second 10mm hex bolt. The second bolt (10mm hex) is the bolt that actually hold the the whole VVTi pulley to the cam shaft. Don't take those 5 small bolts that lines the perimeter of the pulley off unless your VVTi pulley is leaking oil and you're repairing the leak (yes, this is possible without buying a new pulley.) If you're taking the 5 small bolts out, all that you're doing is taking out the front half of the pulley.
ryand
GX - 1st Gen (2003-2009)
02-11-16 08:49 AM
jtwags
04-08-14 08:19 AM
Solo_D33A
11-14-11 09:52 PM
JesLet
Performance & Maintenance
08-18-10 09:37 PM
markpaco
Maintenance
07-06-02 07:38 PM
Quick Reply: Camshaft sprocket question about my 01 IS
