IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Ls1 swapped IS300 stage two power upgrades and swap kit testing
Old 09-11-10, 09:07 AM
  #31
darksyde
darksyde's Avatar
Originally Posted by 03LexIS300
do you know how much the kits are? and how much did they charge you with the kit and installation?
The kit is 1000 and parts and labor run around 10000 but you have 2 supply engine and tranny! The break down is about 5000 for labor and 5000 for parts depending on what parts you go with!
Old 09-12-10, 12:41 AM
  #32
EDTUN3R
EDTUN3R's Avatar
Damn $10k for a Stock LS1 Swap? In A IS. Good Thing I'm Mechanically Inclined
Old 09-12-10, 03:22 PM
  #33
boostinsup
boostinsup's Avatar
damn thats alot of money
Old 09-12-10, 10:42 PM
  #34
03LexIS300
03LexIS300's Avatar
sounds like an awesome swap, but 10k sounds a little too pricey for me, especially for the way it would run. could could turbo the motor or do a supra tt swap for less than 10k
Old 09-13-10, 06:12 PM
  #35
darksyde
darksyde's Avatar
what do you mean for the way it would run??? this thing runs sick!!!!! and strong awesome!!!!! you have to figure the cost of the motor out of a tt supra vs the cost of motor and tranny i paid 4000 for motor and tranny w 69,000 miles very strong and tight!!!! i am more than pleased (except i need more power) after heads cam and either an intake or whipple charger i will be close 2 500-600 at the tires depening on which way i go then it will be insane!!!!!!!!!!!!!!!!!
Old 09-13-10, 09:17 PM
  #36
03LexIS300
03LexIS300's Avatar
oh no doubt its sick and runs strong and awesome, im just saying the way it runs vs. the way a nice built up supra tt swap would, plus v8s generally weigh more, but in your case with a lot of it being aluminum its prabably fairly light. i wasnt saying it didnt run good lol im sure it hauls a**, im just saying for all the work and money involved it in my opinion would be more simple to do a supra tt swap, that whipple charger will make that motor insane in yours.
Old 09-14-10, 10:26 PM
  #37
edgy
edgy's Avatar
have you ever done a Supra TT swap? they are not exactly "simple" at all...ever had to install a return fuel system?....
Quite frankly, in 8+ years on these IS & CL sites, i have not seen ANYONE do a proper high HP ( 450+ ) turbo setup that DIDNT end up spending North of 10k when it is all done.. the biggest issue with trying to go all economical wth a Turbo upgrade or TT motor swap is cutting corners to save that 2-3k will always bite you and every single guy who has done a turbo upgrade for 6-7k or less has bown his motor whithin 3-6 months then he has to go spend another 4-5k+ to get it all done RIGHT and ends up spending 12k or so in the end AFTER gettign a proper fuel system & spending what is needed to get it all properly tuned etc....... usually from mom or dads pocket....and most of them will not post up their misfortune clearly on the boards as no one likes being abused for their decisions... OR .. .they give up & sell the car & move on ....the more likely outcome in the end....
IMO after seeing ALL the years of turbo upgrades TT swaps, aristo swaps etc... the idea of a badass NA relatively light weight V8 setup in this car gives me wood. i have been dreaming of this swap for 5 years and all of a sudden we are seeing them happen from multiple sources.
& I can't remember exactly, but i believe the weight diff between the LS1 & the GE/GTE iron block motors is well under 100 Lbs......more like 75 in the end... swap the battery to the back & you are down to a 50LB weight diff on the front, between motors
Personally i'd prefer solid NA ( gas it up forget about it & beat on it) power in the 450 - 500 HP range from a motor that is not really taxed at that HP level than a Supra TT boosted up and where you always have the potential for a problem that can cause a lean condition under boost & a blown motor....no lag, no surge, no return fuel setups, no broken ring landings, no critical fuel tuning required by specialist tuners at $250 an hour with Dyno time...
& this doesnt event take into the consideration how freeking Bad as hell the LS1 v8 sound with a set of SS headers & a tight Stainless exh system will sound coming out of an IS...
I love SupraTT's & i obviously Love my car & my badass little SUPERcharged GTE block, and my trick custom dual quad Exh..... but the noise an LS1 with a trick exh will make in an IS is just........... The s h i t .
... just a freeking LS1 & a simple basic chip or power commander type tuning for fuel & ignition etc... the GM engine management is cracked & there are many options for tuning that setup..... no fighting with Lexus ECU issues etc. & spending $1500-$2k on standalone EMU's to make it all work....the decil is in the detaisl as they say & the Details involved in upgrading to a GTE motor or even a realy well done Turbo setup on the GE motor are what most people really do not understand.
& an LS1 with an SC... Just Bad Freekin AZZZZ
i will do it some day for sure just as soon as i trash my motor... OR i'll just buy a blown IS & do it & make a track blasting weekend ride.....
IF this swap was available 5 years ago when i had the 1st of a sickening series of supercharger issues that destroyed my custom built GE motor... it would not have even been a question....my mechanic & i talked about it back in the day after he dropped an LSI into his old skewl El Camino and took me for a ride.....
woulda saved me at least 5k as well.
I Say BRING IT... i freek'in WANT ONE . Badly.
Old 09-20-10, 10:30 AM
  #38
BartleDoo
BartleDoo's Avatar
So true.
10char
Old 09-24-10, 03:47 PM
  #39
darksyde
darksyde's Avatar
DGR Fabrication in Redwood city Ca 650-9957685!!!!!!!!!!!1
Dan at DGR has done an LS1 swap into an SC and also has a client that wants to put the viper V-10 in his SC that would be SICK!!!! and the LS1 weighs less than the IS300 motor!
Curated Content Editor
12-07-18 08:17 AM
James4394
12
01-31-14 09:49 AM
Ke0
09-12-12 08:30 PM
6chuchu6
Performance
13
04-26-12 09:57 PM
peffy
09-05-03 06:01 PM
Quick Reply: Ls1 swapped IS300 stage two power upgrades and swap kit testing
