IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
My IS300 won't start
Old 12-10-09, 09:09 AM
hxg94tt
hxg94tt's Avatar
Default My IS300 won't start
My 2004 IS300 with only 22000 miles on , won't start. The battery my be low, but it turns over , just won't start, any help suggestions what it may be.
Old 12-10-09, 12:20 PM
o6spdracer
o6spdracer's Avatar
Did you try jumping it?
Old 12-10-09, 02:19 PM
hxg94tt
hxg94tt's Avatar
Yes I tried jumpping it, only cranks faster, battery is low from my wifes attempts at starting it.
Still has over half tank of gas ,(fuel is good).I can hear fuel pump when the key is turned ..
would the security system have anything to do with it ?
Old 12-10-09, 02:56 PM
ATX300
ATX300's Avatar
I would take the battery to an auto parts store and have them check the amount of charge left. In regards to the security system, is the steering column locked?
Old 12-10-09, 03:40 PM
hxg94tt
hxg94tt's Avatar
Steering column is not locked (when key is turned)
Old 12-10-09, 08:57 PM
VinnRock
VinnRock's Avatar
is the engine turning over?
Old 12-11-09, 03:16 AM
hxg94tt
hxg94tt's Avatar
^^^ Yes it turns over ^^
Old 12-11-09, 10:00 PM
VinnRock
VinnRock's Avatar
might check spark plugs or coil packs or if you have the electronic key under the steering colum by the hood latch if its damaged or missing.
Old 12-12-09, 07:42 AM
hxg94tt
hxg94tt's Avatar
After two days with no luck.. tried to start it this morning, turned over about 3 times & started , a little rough idle at first then smoothed out , drove for a while everything seems fine now ..
Old 12-19-09, 10:53 PM
BOXCAR
BOXCAR's Avatar
Check the air filter and MAF. I had a rodent that ate mine and my car broke down a mere 1/4 mile after I purchased it. Crazy ****e.
Bpb713
09-19-12 07:56 PM
pinto096
03-27-11 09:00 AM
gotrice111
03-26-10 02:49 PM
92lexus
Maintenance
12
02-13-03 07:14 AM
Quick Reply: My IS300 won't start
