"Fog Enable" Mod??
"Fog Enable" Mod??
hey guys, ive been searching around to find out how to do the "Fog Enable" mod for the is300 and once again i come back with no luck....does any1 know how to do it?....i hear its a pretty simple process?....any info appreciated...thanks
You're looking for the fog mod. You have two options for the fog mod. The first is easy and you just bend a prong on the fog relay and run a wire from that prong to the ignition fuse. The second is pretty much the same concept but using a Mini Add-A-Circuit instead. More wiring is involved with the second method but you leave the fog relay intact without bending a prong, which should be easier to convert back to stock.
Good luck.
Good luck.
