IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
IS300 unlocked then died-DEAD
Old 07-11-06, 05:56 AM
dscottp
dscottp's Avatar
Default IS300 unlocked then died-DEAD
Hi Folks,
My daughters 01 auto IS 300 popped the trunk, unlocked the doors, lit up the dash but when she tried to turn it over it went dead. No cranking. Cannot lock the doors or any electrical function. Totally dead. My question is this. Does the security system in the car disable it totally? I would assume even a weak battery would still set off the door locks.
I once had a bad battery in a LS 400 and once the battery was replaced I had to do a dance with the key and outside door lock to get the starter to turn over (security shutdown). If that may be the case how do you reset it?
Thanks for the help!
Old 07-11-06, 09:19 AM
rominl
exclusive matchup
rominl's Avatar
don't think it will just "disable" everything ,but i am not 100%
have you tried to jump the car or put in a different battery?
Old 07-11-06, 02:30 PM
toekneepark
toekneepark's Avatar
sounds like the battery might be completely dead. if that's the case your electrical components won't work includeing the alarm etc...
Old 07-13-06, 11:11 AM
revsteve
revsteve's Avatar
If the battery was dead then things wouldnt work up front.
I have had this problem SEVERAL times w/ my 93 Rx7. It usually occurs after working on it and not paying attention to things like making sure the battery cables are on securely
Check the battery cable connections and jiggle them around a little bit. Just b/c they are on there snugly doesn't mean its completing the circuit. Also - check the terminals or cable ends for corrosion. This could cause it as well.
Old 07-13-06, 02:41 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Originally Posted by dscottp
Hi Folks,
How old is the battery in the car? And has it been replaced before?
Old 07-13-06, 03:18 PM
formosa927
formosa927's Avatar
it doesnt hurt to try jump the car. sounds like a battery issue to me
Old 07-16-06, 09:58 AM
AgentEzzard
AgentEzzard's Avatar
Its probably the terminals. Built up corrosion between the post and terminal is a possibility. It happened to two of my toyotas.
USCRugby
10-17-18 09:42 AM
white93nsx
03-22-15 06:59 PM
JiggsHall
03-20-15 10:41 AM
funkymack
10-07-14 07:43 AM
Black94RX-7TT
06-07-02 08:40 AM
Quick Reply: IS300 unlocked then died-DEAD
