ls430 throttle body will it fit is300
its actually from a LS/GS400
currently the trick mod of choice by Toyomoto Turbo and S/C cars...
you cannot just "slap" it on....it needs to be custom cut and welded onto the intake manifold Y piping...I suggest if you're in cali, try SP ENGINEERING
good luck!!
good luck!!
The LS/GS/SC400 share the same engine and therefore throttle body. It measures 75mm. The work and cost necessary to use this larger unit would be substantial. Because of this I have 2 questions: What is the IS300 tb size? Is there even a documented improvement to going larger? Maybe above 600hp... maybe... but below that... I would need to see strong evidence of substancial improvement.
exclusive matchup
Originally posted by rominl
just to clarify, the early yrs ls400 and sc400 they had a different v8 engine than the later yr ones. i am not sure about the tb sizes though
JPI
cvc9216
09-09-15 01:59 PM
