SAFC setting
SAFC setting
I need help!! Does anyone have settings for the SAFC controller?? I know that it is going to be different on all cars but are there general settings???
Here are mine:
High Throttle Settings (50%)
<3000rpm - 0%
3000rpm - 0%
3400rpm - +3%
3800rpm - +1%
4200rpm - -7%
4600rpm - -11%
5000rpm - -10%
5400rpm - -9%
5800rpm - -9%
6200rpm - -11%
6600rpm - +1%
>6600rpm - +1%
I did not change any of the low throttle settings. The guy who set mine up said that the ECU takes over at low settings so it is not worth changing. Here is what I have for mods:
'03 E-Shift
PLP Silent Flow Intake
TRD Filter
Toyomoto Gen 1 Headers (Stock Y Pipe)
HKS Ti Limited Exhaust
I highly recomment getting to a dyno and check the #'s out. You should do a dyno with no adjustments. Any tuner worth a **** can get it done with no numbers in 4-5 pulls max. If you have a manual transmission DO NOT USE THE #'s ABOVE. They are totally different.
<3000rpm - 0%
3000rpm - 0%
3400rpm - +3%
3800rpm - +1%
4200rpm - -7%
4600rpm - -11%
5000rpm - -10%
5400rpm - -9%
5800rpm - -9%
6200rpm - -11%
6600rpm - +1%
>6600rpm - +1%
'03 E-Shift
TRD Filter
Originally posted by sexylex84
I do have a manual transmission...Does anyone know the settings for that??
Scott provided some general numbers like you asked for above, but that doesn't mean it's the best for your car as you know. I think an hour of tuning should be enough to tune a SAFC.
Originally posted by Lexan
Do you happen to have the wire schematic to hook up the afc to my IS300 auto?
