Oil Level Higher When Engine Cool?
Old 06-06-15, 09:14 PM
iamevan
iamevan's Avatar
Default Oil Level Higher When Engine Cool?
So I changed my oil today and added about 9.8 - 9.9 quarts. There was just a little left in the second 5 quart jug. I carefully added some oil while checking the dip stick frequently. I made sure the level was just at (maybe a hair above) the top dot on the dip stick. After that, I went out for a spirited drive.
Now 4 hours later, when the car is relatively cool, I checked the level again. However, the level is now significantly higher than before. It's definitely past the top dot, not by a lot, but definitely more than before.
Old 06-07-15, 03:51 AM
Sceanzo
Sceanzo's Avatar
Completely normal. When the engine cools, the oil drains back into to oil pan.
Old 06-07-15, 05:48 AM
iamevan
iamevan's Avatar
Gotcha. I guess that is why in the DIY maintenance manual says to:
Park the vehicle on level ground. After warming up the engine and turning it off, wait more than five minutes for the oil to drain back into the bottom of the engine.
I don't think I overfilled it either. I only had the two 5 quart jugs to fill it with. I had the car up on Race Ramps and let the oil drain for about 15 minutes. By having the car higher in the front compared to the rear, I imagine that allowed for more oil to drain as opposed to having the car level on the ground.
Old 06-07-15, 08:02 AM
Sceanzo
Sceanzo's Avatar
Yes, you're completely fine. Oil should be checked when the engine is at operating temperature.
Old 06-07-15, 09:23 PM
F_Throttle
F_Throttle's Avatar
Crap. I've been checking oil cold..
Old 06-08-15, 09:54 AM
Sylvan
Sylvan's Avatar
I always check it cold as well, the main concern is that you have oil in the engine. A little high or a little low won't kill anything.
Old 06-08-15, 04:38 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
I always put 9 in 1st... then go back after a bit to add in the amount needed to get to the dot.
~ Joe Z
songlou
01-07-16 02:14 PM
tea
08-18-15 10:22 PM
shiny250
11-30-13 06:55 PM
lx470man
IS F (2008-2014)
06-11-09 08:57 PM
jimjaix
09-06-07 12:15 PM
Quick Reply: Oil Level Higher When Engine Cool?
