0 offset on ISF?
Old 05-17-15, 10:06 PM
teamcalvin
teamcalvin's Avatar
Default 0 offset on ISF?
Just purchased some VIP Modulars vx110 with the specs:
19x9.5
19x10.5
Both are which 0 offset... Has anyone ran these specs before? if so, how much work did you have to put into them in order for them to fit perfectly? My ISF is also going to be bagged by the time the wheels will be here, which is in a couple of days.
Old 05-17-15, 10:40 PM
shyguyF
shyguyF's Avatar
IS F 2008 - 2011 front 19 x 8 +45
rear 19 x 9 +55
Your new wheels are 19 x 9.5 +0.( 9.5 - 8 = 1.5 = 38mm/2 = 19mm +45mm sticked out from +0 offsets =64mm )
19 x 10.5 +0 ( 10.5 - 9 = 1.5 = 38mm/2 = 19mm +55mm = 74mm )
I don"t know if your new wheels will work on your F ?
Old 05-18-15, 01:53 AM
KdotAmes
KdotAmes's Avatar
Running 19x9.5/11 in a +25 offset.
Im not lowered yet so i needed a slight pull and roll to make my setup work. (Also poking 1/2inch)
Your gonna need to do pull/roll and a aggressive amount of camber and it still might not work.
Not really worried about the rear, as long as you have adjustable LCA. But not sure how your gonna get enough camber for the front...
(Maybe SPC ball joint, T-Demand UCA, and FIGS UCA bushing?)
Either way if theres a will, theres a way. Keep us updated :thumbsup
Edit: Heres an idea of what it'll look like. But an inch wider in the front and half an inch in the back... GL
https://www.clublexus.com/forums/whe...lish-lips.html
Oh and i can't go full lock while turning without rubbing a good amount, so turning with an extra inch is gonna be a problem in parking lots and driveways.
Old 05-18-15, 03:56 AM
jleonard71
jleonard71's Avatar
I honestly don't think that'll work no matter how much work you do, unless you run some insanely ridiculous setup with super stretched tires and -20 camber.
Old 05-18-15, 04:56 AM
ZaxF
ZaxF's Avatar
You're going to have some wheel poke. And by some I mean
Old 05-18-15, 05:39 AM
Jamakan
Jamakan's Avatar
U may need to chop up your fenders and put some fender flares on. Not worth it. . . Well depends which direction u wanna go with your car?? Function or stupid hella flush gangster stretch camber style.
Old 05-18-15, 09:14 AM
teamcalvin
teamcalvin's Avatar
haha, thanks for everyones opinion. The wheels are being shipped out today, and were going to have to see how much work is going to be done. If it wont work, then i'll just flip them since i got them for a buddy price.
Old 05-18-15, 10:02 AM
93MSB
93MSB's Avatar
here is a comparison tool to show you the differences between wheel/tire sizes
http://www.rimsntires.com/specspro.jsp
this is about what your looking at for the fronts:
Old 05-18-15, 10:34 AM
streetx
streetx's Avatar
Damn 0 offset...
Widebody time
Old 05-18-15, 10:37 AM
Sylvan
Sylvan's Avatar
Run 205mm tires...
Old 05-18-15, 02:18 PM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
No way those are going to work without crazy amount of work done. Either super skinny crazy hella JDM stancenation tires or custom widebody with bags (hint hint) haha.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 05-18-15, 02:27 PM
I8ABMR
I8ABMR's Avatar
damn I am surprised you ordered them that way unless you were planning on doing some body work
Old 05-18-15, 07:14 PM
DEMIK
DEMIK's Avatar
hope they are 9/10 condition like the sp3's
Old 05-21-15, 08:24 AM
teamcalvin
teamcalvin's Avatar
The fitment wasn't as bad as we thought, so since i'll be on bags pretty soon... i think my shops going to fit them with camber arms and a pretty nice pull.. i'll update as soon as we get everything situated.
Old 05-21-15, 08:34 AM
jiggahwh0
jiggahwh0's Avatar
u can do it i was running 19x10 19x11 with +5 front and 0 offset rears just run a 225/35 up front and the rears would be tucking but i ran 245/35
Quick Reply: 0 offset on ISF?
