ISF shifts issue
Old 03-14-15, 09:20 AM
SEEMO
SEEMO's Avatar
Default ISF shifts issue
Hello guys,
I'm a new member here
My friend just bought his ISF two weeks ago. It's bolts-on.
He has an issue
While hard accelerating in all modes the car some times shifts @5500 RPM
Does any body know what the problem is?
Old 03-14-15, 09:58 AM
Justind27
Justind27's Avatar
Sometimes mine does this in auto mode after riding out the gears in manual mode
Old 03-14-15, 02:15 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
If the skid control ECU detects wheelspin on launch, it will limit power output temporarily because it assumes the road is slick. It sounds like you're spinning the tires under acceleration (or you have an issue with wheel speed sensors) and the skid ECU is stepping in to make sure you are safe in low traction conditions.
Old 03-14-15, 06:45 PM
j3ff
j3ff's Avatar
Sounds like he just isn't pushing the pedal hard enough. He'll have to push past the throttle kickdown button. When in auto, the car will always try and shift at lower rpms. Even with sport mode, if you don't pin the pedal, it's not going to shift at redline.
Or the car is broken... Haha.
Old 03-14-15, 07:34 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
All true. I fixed my kickdown switch so long ago, I've forgot how hard it was before I modified it.
Old 03-14-15, 09:34 PM
93MSB
93MSB's Avatar
Lobux,
Could you please explain what you did to modify the kickdown
Old 03-14-15, 09:51 PM
flowrider
flowrider's Avatar
Received 1,829 Likes on 1,291 Posts
^^^^Read this thread:
https://www.clublexus.com/forums/is-...gas-pedal.html
Lou
Old 03-14-15, 09:58 PM
93MSB
93MSB's Avatar
Thanks Lou!
Old 03-15-15, 09:07 AM
YotaLex
YotaLex's Avatar
Damn kick down button. I was lined up with a 335i with some mods and he stayed at my mirror. I thought I was all the way in it but I found out she had more to go and started walking. Now I just stomp it when stoplight racing
Eurofreak
IS F (2008-2014)
08-25-17 11:01 PM
kenysl
IS F (2008-2014)
15
04-19-11 03:30 AM
IS350atWOT
IS F (2008-2014)
12
04-01-10 02:16 PM
Dave600hL
IS F (2008-2014)
23
02-27-09 03:20 PM
CrazyMPG
IS F (2008-2014)
03-07-08 09:10 AM
Quick Reply: ISF shifts issue
