Leaking Tires
Leaking Tires
Just wondering if this has happened to anyone else. A few months ago I developed a slow leak in my drivers front tire. I took it to a local tire shop and they told me small sections of paint on the inner part of the rim that sits on the bead of the tire was corroding and flaking off causing a small air leak. They sanded it down and resealed the paint and it stopped the leak. I asked them if it happened to this rim, could it happen to all of my rims? They couldn't answer that, but now I think I know the answer. 2 of my other wheels now are losing air and I bet it's the same problem. Has anyone else come across anything like this...Is there a recall of some kind? Dealer says since my car is out of warranty, they can't do anything. Thanks!
Not to say the paint isn't your problem, but have you checked to see if the tiny hairs from the tires are the cause? I've had tire hairs on the sidewall that get caught between the rim and that would create a really slow leak. Might be worth a look.
I had this problem on an old SC300 with SC400 chromed wheels. I lived in Southern California when I bought the car, and everything was fine there. I later moved to Virginia, and during the first winter, I developed slow leaks in three wheels, all caused by the chrome paint flaking around the inside of the bead area. I assumed the road salt caused the condition. I replaced all the wheels with after market (don't remember the brand) and vowed never to own chrome wheels again. And now my taste has changed, and I don't even like chrome wheels
Lou
Lou
Thanks everybody. Yeah, it isn't the valve stems, it's the corrosion under the paint that's doing it...gonna cost about $300 to do the two wheels and who's to say if more "spots" pop up later...Maybe this is a good excuse to get some aftermarket wheels on the ole F huh? Lol
the problem you listed does happen, but its usually on aftermarket wheels from what ive worked with.
best think to do to locate an air leak is to drop the entire wheel with air inside of a water tank at places like discount tires. you will find where its coming from. its not rocket science.
Tech Info Resource
This why I had the wheels powdercoated with a clear finish over the black paint when I had my wheels done. It is a lot harder to have flaking issue with powdercoating.
had valve stem issues with my suv all in last few months one had a small crack and was super slow leek thought maybe the wheel . Other loose stem pain in the as(/-. But happy to tighten it and go. Too simple some times wish all like that.
D-MAN63
11-14-01 04:22 PM
