Lexus ISF Skid Plate
Old 11-22-14, 06:21 PM
jadeboy
jadeboy's Avatar
Default Lexus ISF Skid Plate
Since lowering the ISF, the front skip plate (highlighted in Red below) makes a horrible noise when I hit a bump or drive over a lower section of the road (road in my city Calgary, Alberta, Canada sux).
Anyone has suggestion how to reduce the horrible noise.
Old 11-22-14, 06:41 PM
shyguyF
shyguyF's Avatar
no way to do man, try to avoid big bumps or crappy roads or return to stock drive height.
Old 11-23-14, 06:22 AM
FNSSESPORT
FNSSESPORT's Avatar
You could remove them? Just 3 or 4 push-in style clips.
-R
Old 11-23-14, 06:26 AM
Lmood
Lmood's Avatar
They are just plastic and will eventually wear down. Like above said remove them.
Old 11-23-14, 12:28 PM
Justind27
Justind27's Avatar
I took mine off, was a few 10mm bolts. Just put the bolts back in cause it supports the under fairing.
Old 11-24-14, 07:50 PM
jackhui
jackhui's Avatar
are you sure its those flaps and not your fender liner?
i lowered and one section of the fender liner started rubbing when i was reversing at a certain angle.
The vents were scrapping the tire. i just cut the piece out and everything was good
Old 11-24-14, 08:18 PM
jadeboy
jadeboy's Avatar
It's the flaps.. and the fender liner that causing problems..
Right now I have removed the flaps.. it is still making noise from the fender liners.. but it's not as bad..
I used a heat gun to push the fender liner in as much as possible. Would you please take some pictures of what you did with your fender liner.
Old 11-24-14, 09:35 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
The "flaps" reduce drag and improve fuel economy as well as top speed if you can remove the speed limiter.
Old 11-25-14, 04:31 AM
NotnFsport
NotnFsport's Avatar
Finally someone knows!! Im installing soon a bigger version in the center section. Its from the dynamic sport tuning package out of Japan.
Old 11-25-14, 04:48 AM
NotnFsport
NotnFsport's Avatar
Not my car but same part/idea.
Sirguy01
04-24-16 04:58 PM
Mistr2
04-14-16 11:31 AM
osh3is350f
05-13-15 08:35 PM
OCLEX03
01-11-12 09:34 AM
Quick Reply: Lexus ISF Skid Plate
