Heat goes off when stopped it at idle
Old 10-23-14, 09:13 AM
ttbasterd
ttbasterd's Avatar
Default Heat goes off when stopped it at idle
So I got my 2010 ISF last year around this time.... I never noticed anything a possible heat problem... So basically I've noticed that when ever I stop at red lights or at idle, my heat turns cold? Temp is at high and the AC light is off too... When ever I drive it warms up again and works like a champ... But at idle or stopped it's completely cold....
Anyone else experienced this in the past? It's scaring me.... My car is certified still I believe, this problem should be covered since it's internal?
Old 10-23-14, 09:31 AM
MisterSkiz
MisterSkiz's Avatar
Look at your coolant level in your coolant reservoir...it is probably very low or gone.
If its low or gone, it leaking somewhere...most likely water pump.
If you are still under warranty take it in and wash your hands of it.
Old 10-23-14, 10:54 AM
sTeadFasT
sTeadFasT's Avatar
This could be caused by air in the coolant system.
You're going to need to bleed the air out.
Old 10-23-14, 10:59 AM
Navaz
Navaz's Avatar
Maybe you have a bad thermostat, I had that happen twice on my old gs400.
Old 10-23-14, 12:11 PM
Dupshaw123
Dupshaw123's Avatar
check your coolant level and also check your radiator. I had a similar issue and it ended up being the radiator was completely shot. leaks around the entire top perimeter of the radiator.
Old 10-23-14, 02:07 PM
jlam86
jlam86's Avatar
I have the opposite problem. My car always seems like it's really warm when you have the vents on the non circulating mode.
Lexus told me it's the tyranny giving off all the heat into the cabin. Is this true?
Old 10-23-14, 02:34 PM
MisterSkiz
MisterSkiz's Avatar
The temperature you set the car at is what the blend door will be set to regardless if the fan is on or off.
if your car is too hot, you need to turn on the fan...set your temp to the lowest and then turn off the fan.
its a bad design not being able to modify the temp without the fan being on..
xCWolf
Performance & Maintenance
09-02-18 08:26 AM
Stroock639
02-17-16 12:10 PM
JDW379
12-01-13 05:17 PM
Max Power
10-14-10 04:22 AM
ONe21
02-01-05 05:53 PM
Quick Reply: Heat goes off when stopped it at idle
