First Lexus - '08 IS F - Questions
Old 08-28-14, 11:50 AM
srt4evah
srt4evah's Avatar
Default First Lexus - '08 IS F - Questions
Hi all, I just purchased a 2008 Lexus IS-F yesterday and it was 100% stock except for the K&N intake and Michelin Pilot Super Sport tires.
I have a few questions, and I've spent a ton of time reading the forums here so hopefully these aren't well-covered already and I didn't just miss the answers that are already here.
Regarding the intake, I've seen the intake "shootout" threads and dyno tests here, and the consensus opinion is that the unprotected cone-filter intakes are subject to heat soak and basically reduce power significantly. However, I read the review of the K&N intake at MotoIQ and they showed a 23-30hp gain on the dyno. That doesnt match up with the opinions I seem to have found on a lot of the threads.
All that said, I'm still more inclined to pick up a Joe Z or F Sport intake, but since this car came with the K&N intake, I don't have the stock airbox. Is that expensive to pick up?
Also had a question about Bluetooth, is there any way to get factory Bluetooth music streaming added, like a later model head unit or anything?
And is there a Lexus remote start that allows you to use one fob only to start and drive the car, that doesn't shut the car off when you open the door? I've searched the web and I can't find anything on the Lexus websites.
I'm also planning to get a 2013 suspension and a 2012 steering control module.
I apologize if any of these questions are buried somewhere here on the site, I have done a ton of reading in the last 48 hours and I did find answers to a lot of questions I had, but I also found follow-on questions to a lot so I'm throwing it out there for anyone that's willing to take a stab at it.
Thanks in advance =]
Old 08-28-14, 12:01 PM
BlackISFtx
BlackISFtx's Avatar
iSIMPLE ISTY651 I picked this up for my 08' to stream music via bluetooth. I believe it works for both android and iphones.
Old 08-28-14, 12:28 PM
srt4evah
srt4evah's Avatar
Oh awesome, thank you. How do you select it from the stock unit when you want to connect and play music?
Old 08-28-14, 01:44 PM
Quadrphnia
Quadrphnia's Avatar
Next weekend I'm installing the following on my 08 with help:
ISBT21
SVX200
ISTY12
+ the nav and DVD bypass from Beatsonic
If you'd like, I can post again with a detailed description of the functionality.
Old 08-28-14, 02:07 PM
swoo350
swoo350's Avatar
I am pretty much in the same boat as you when it comes to intake. I bought my 08 ISF and came with SRT Intake (previous owner obviously just like noise because of the negative feedback on the SRT intakes for ISF model). I've asked forums before and I believe the stock airbox is about $450-500. I'll find the thread that I started which gives you the part# and everything.
EDIT: https://www.clublexus.com/forums/is-...rt-number.html
Old 08-28-14, 02:53 PM
ISF4life
ISF4life's Avatar
Congrats and welcome
Old 08-28-14, 06:09 PM
digger08
digger08's Avatar
Air box is stupid expensive....
Digger08
Old 08-28-14, 07:26 PM
speeddem0n
speeddem0n's Avatar
Awesome thanks, ill have to check this out as well for my 08.
Old 08-28-14, 08:27 PM
v8sten
v8sten's Avatar
ill be following this thread, i have a lot of the same questions
Old 08-28-14, 09:38 PM
srt4evah
srt4evah's Avatar
Man, seems like there are a ton of ISF owners in Texas. I'm in Austin.
I guess buying a stock airbox is probably a huge waste of money, so I'll have to look around and see what the next best option is with a good heat shield. I'm probably going to stick to the stock exhaust, I bought the car primarily for my gf to drive and she isn't into the loud stuff.
I'll call Sewell and ask about the remote start and 2013 suspension, and the steering module, see what their prices are.
Old 08-29-14, 02:52 AM
kauaian
kauaian's Avatar
I have an extra stock air box. I'll send you a PM with details.
Old 08-29-14, 07:18 AM
zen
zen's Avatar
I'm also looking for the oem intake, just the half portion that's next to the fender with clips.
Old 03-22-15, 03:18 PM
VDODSON
VDODSON's Avatar
Does the song information display on your screen, and if so, can you use the screen to make selections?
Old 03-22-15, 03:26 PM
KOKISF
KOKISF's Avatar
Does your 2008 has nav? If not get a flyaudio 2generation you wont regret it and there you have all sords of conections to stream music , theyre available in ali express
Imo the stock air box i the way to go try on a junk yard or ebay
My car does not start w the key fob but it does not shut off it self when i open the door
Miggy2349
08-19-20 06:49 AM
Tro209
10-03-15 09:39 AM
ISFTOMMY
IS F (2008-2014)
06-24-15 12:01 PM
NTXISF
IS F (2008-2014)
66
02-03-12 10:05 PM
C-Red
IS F (2008-2014)
13
07-08-10 04:57 PM
Quick Reply: First Lexus - '08 IS F - Questions
