Vinyl wrapping over clear bra?
Old 02-24-14, 08:21 AM
ISFalex
ISFalex's Avatar
Default Vinyl wrapping over clear bra?
Hello, I want to wrap my mirrors in carbon fiber vinyl (like my window pillars). My problem is I have a piece of the clear bra on the mirror. can I remove the bra or should I wrap over it? Suggestions? Pic below. thanks
Old 02-24-14, 10:09 AM
Boma
Boma's Avatar
Should be all right to layer the vinyl on top.
On that note, I wouldn't replace a clear bra in good condition with vinyl that wouldn't last as long.
Old 02-24-14, 11:33 AM
ISFalex
ISFalex's Avatar
Originally Posted by Boma
Should be all right to layer the vinyl on top. On that note, I wouldn't replace a clear bra in good condition with vinyl that wouldn't last as long.
it's 3m brand, so it is high quality and guaranteed for a while. When I pull the vinyl off, will it remove the clear bra? I don't want my paint damaged.
Old 02-24-14, 03:58 PM
I8ABMR
I8ABMR's Avatar
I dont think it will be a problem at all. Where are you having it done.
Old 02-24-14, 05:27 PM
ISFalex
ISFalex's Avatar
I was going to TRY to do it myself. If that doesn't work, I may to to a local customs shop. I have enough vinyl to attempt it (I think )
Old 02-24-14, 06:28 PM
digger08
digger08's Avatar
IMO....It will look funny and definitely create an air pocket, as the vinyl will be too stiff to sit on that crease line flush.
The hardest part about wrapping a mirror like this, is to keep the carbon fiber weave
from distorting...the more you heat and stretch, the more pattern distortion will occur. So take your time and work the piece slowly, and try to keep the weave straight.
Good luck, it will probably take a few attempts...to get something you will be happy with.
Digger08
Old 02-25-14, 08:40 AM
ISFalex
ISFalex's Avatar
Originally Posted by digger08
IMO....It will look funny and definitely create an air pocket, as the vinyl will be too stiff to sit on that crease line flush. The hardest part about wrapping a mirror like this, is to keep the carbon fiber weave from distorting...the more you heat and stretch, the more pattern distortion will occur. So take your time and work the piece slowly, and try to keep the weave straight. Good luck, it will probably take a few attempts...to get something you will be happy with. Digger08
Do you know if I can remove the clear bra safely so I can wrap it?
Old 02-25-14, 11:19 AM
digger08
digger08's Avatar
Yes just use a heat gun to soften the material and pull it back on an edge....just be careful not to pull to hard and lift any paint underneath...go slowly, our paint is pretty strong.
Its all about angles so try to pull or force it back on itself using the heat gun. It can't be very old, and its such a small piece it should come off fairly easily.
Digger08
Old 02-25-14, 11:34 AM
ISFalex
ISFalex's Avatar
Yes just use a heat gun to soften the material and pull it back on an edge....just be careful not to pull to hard and lift any paint underneath...go slowly, our paint is pretty strong. Its all about angles so try to pull or force it back on itself using the heat gun. It can't be very old, and its such a small piece it should come off fairly easily. Digger08
it's from 2008. it came with the car. I'm just nervous about it.
Old 02-26-14, 05:46 AM
PTmobile
PTmobile's Avatar
You will want to remove the vinyl. If not you will see the film through the vinyl... as in you will see the line where the film stops and it will make an indention through the vinyl. The ideal way to do this is apply the vinyl first, then clear bra over the vinyl. Vinyl will tear and scratch fairly easily so the film will protect it from that. We do this all the time without any issues.
Old 02-26-14, 11:15 AM
ISFalex
ISFalex's Avatar
How should I remove the vinyl? Like this?
Thanks
Old 08-30-17, 09:43 AM
F Monster
F Monster's Avatar
Has anyone ever done this? My car has a clear bra on both mirrors but I want to wrap them in glossy black vinyl but do not want to remove the clear bra. I just want to know if I can preserve the clear bra underneath once I take the black vinyl off in the future.
Old 08-31-17, 08:43 AM
3nergiz3d
3nergiz3d's Avatar
When vinyl wrapping over clear-bra with areas that are not tucked, you'll most likely see the seam, but overall... there is no problem wrapping vinyl over clear-bras. In my experience and for longevity, it's better to remove the clear-bra and just apply the vinyl wrap to your mirrors. It will adhere better, and we can't tell how dirty your mirrors are and what kind of dirt or contaminants are left behind.
John510
10-14-13 04:17 AM
KKM
CT 200h Model (2011-2017)
05-09-13 09:59 AM
gsrthomas
Automotive Care & Detailing
35
02-13-07 06:31 AM
Tony1
04-12-06 12:41 PM
CVsIS250
GX - 1st Gen (2004-2009)
13
04-10-06 11:47 AM
Quick Reply: Vinyl wrapping over clear bra?
