Stereo no recognizing new song on iphone / songs freezing
Old 02-06-14, 08:41 AM
2URGSE
2URGSE's Avatar
Default Stereo no recognizing new song on iphone / songs freezing
I downloaded a new song to my iphone yesterday, yet the NAV/Stereo does not see it. I checked under songs and artists and it's not there. iphone connected via USB cable.
2. Today, I played another song, and it froze on me.
Anyone else?
Old 02-06-14, 08:53 AM
Boma
Boma's Avatar
Sounds more like an iPhone issue. Maybe you had a bad download?
Old 02-06-14, 08:58 AM
2URGSE
2URGSE's Avatar
Well, it plays fine if I click play on the phone but the car doesn't see it.
Old 02-06-14, 09:14 AM
2URGSE
2URGSE's Avatar
As a test, I created a playlist on the phone with just that particular song. The car sees the playlist, but the song isn't there. Maybe you're right.
I guess I need to hook the phone to a computer and delete the song.
What a hassle...oh well.
Old 02-06-14, 05:32 PM
2URGSE
2URGSE's Avatar
I decided to conduct another test. I tried to download the same song from my work iphone,only to see it does not even appear on the phone itself.
At this point I think I will start experimenting with downloading songs for free from youtube to USB.
Old 02-07-14, 05:06 AM
ULTSISF
ULTSISF's Avatar
I use my iPhone w the F via Bluetooth. No issues with any songs thus far
Old 02-07-14, 08:53 AM
2URGSE
2URGSE's Avatar
It's something with the iphone.
I will buy another random song just for the heck of it, and see if the car sees that.
Old 02-07-14, 10:42 AM
Mydogbella
Mydogbella's Avatar
By chance are you downloading from iTunes or frostwire?
Old 02-07-14, 02:14 PM
2URGSE
2URGSE's Avatar
iTunes, directly from the phone, then plug the phone to the car.
Old 02-07-14, 04:49 PM
ULTSISF
ULTSISF's Avatar
What I don't get is this....why are u even using a cable when u can have a cleaner set up by just using the Bluetooth....
Old 02-07-14, 05:57 PM
lilcop17
lilcop17's Avatar
speaking of this... how do you connect blue tooth with an iPhone in a 2008 F for playing music????
Old 02-07-14, 06:04 PM
ULTSISF
ULTSISF's Avatar
U just have to pair your phone w the car but is that even available on the 08's. I'm not sure
Old 02-07-14, 10:03 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
There is no A2DP for '08 MY cars. Gen 5 nav does not support anything but calls and address book maintenance with the phone. No audio except through the aux input with a wire, unless you buy an iPhone kit (if you have an iPhone).
There are
BT modules BT modules
you can buy and plug into the aux port for A2DP. You will likely need a ground loop isolator on the aux input for this to work without alternator noise. If your car is still under warranty, you can get this done by Lexus. If not, you'll need to have it done by someone familiar with electronic devices and automotive wiring.
Old 02-08-14, 05:11 AM
lilcop17
lilcop17's Avatar
Thumbs up
There are BT modules you can buy and plug into the aux port for A2DP. You will likely need a ground loop isolator on the aux input for this to work without alternator noise. If your car is still under warranty, you can get this done by Lexus. If not, you'll need to have it done by someone familiar with electronic devices and automotive wiring.
thanks for the info, ill just stick with pandora lol sounds really complicated haha.
Old 02-08-14, 06:04 PM
2URGSE
2URGSE's Avatar
Because it charges the phone as well.
Quick Reply: Stereo no recognizing new song on iphone / songs freezing
