headlight tab repair
Old 12-18-13, 09:16 AM
scamsel
scamsel's Avatar
Default headlight tab repair
does anyone have any experience with these headlight tab repair parts:
RH Upper: 81193-53020
RH Lower: 81195-53010 (Closer to the grille)
LH Upper: 81194-53010
LH Lower: 81196-53020
just wondering how well they work and what are the requirements, ie do you need part of the existing tab intact?
thx
b
Old 03-14-17, 12:46 PM
lawrence1
lawrence1's Avatar
bump. interested in this and figured i'd see if anyone has used these successfully.
Old 03-14-17, 01:06 PM
STLblueF
STLblueF's Avatar
I have. In my opinion they work really well. You will need to trim off the tab in place with either a dremel or similar tool(but be careful not to grind down into the actual housing). You don't need any part of the existing tab, but you will need the two screw holes in the surround to be intact. The new tab is secured to the housing by two screws, and functions just like the built in tabs if done correctly. I'm somewhat surprised the engineers had the foresight to include provisions for replacing the main tabs but I'm certainly glad they did. They work much better than trying to glue back on broken tabs.
Old 03-14-17, 06:21 PM
Rickna
Rickna's Avatar
I used the top replacements (the ones that clip to the fender) with great success. As STLblueF said, be careful grinding down the broken tabs.
Old 03-16-17, 06:17 PM
lawrence1
lawrence1's Avatar
Thanks for the feedback. I'll order these and give them a shot. Ill keep you all posted on the results
tommigsr
08-10-19 08:02 PM
jhong28
CL of Southern California
04-06-15 01:28 AM
Vibes63
04-15-14 03:49 PM
J2K
Lighting
01-20-14 11:25 AM
Quick Reply: headlight tab repair
