20" wheel/tire fitment help
Old 08-13-13, 04:44 PM
  #31
shyguyF
shyguyF's Avatar
Originally Posted by ROK
murph man, having the darndest time nailing down offsets as calling the Work Wheel guys in Cali wasn't too much help in finalizing the numbers for ISF fitment. They don't have any recommended sizing for 20x9, 20x10.5s with close to stock diameter tires in 245/30, 285/25. Pretty much have to lean on you guys end of day.
What's really low? I just want zero wheel gap in the rear lowered like this one:
http://www.iputinwork.com/?p=3662
So are my specs below too aggressive given my fitment requirements?
20x9 ET38, 245/30 MPSS
20x10.5 ET45, 285/25 MPSS
or should I be looking at pushing it to 43+ up front and 50+ in the rear?
why do you get 285/25 in the rear , it"s about 5.5mm shorter in diameter. You know 295/25 is still 3mm shorter than stock tires.
To me you should get 20x11 +52 with 295/25 better, the 295 on 11" wheels does not look stretch.
Old 08-13-13, 04:50 PM
  #32
ROK
ROK's Avatar
great point - much obliged!
So how about this then?
20x9 ET42, 245/30 MPSS
20x11 ET52, 295/25 MPSS
Old 08-13-13, 05:06 PM
  #33
Murph145
Murph145's Avatar
Do +35 front then your set
Old 08-13-13, 05:29 PM
  #34
ROK
ROK's Avatar
So...?
20x9 ET35, 245/30 MPSS
Old 08-13-13, 05:33 PM
  #35
Murph145
Murph145's Avatar
Now we're talking
Old 08-13-13, 05:36 PM
  #36
ROK
ROK's Avatar
Now we're talking
So if i told my vendor to submit this order with that spec... it won't rub, won't require any mods to my new ISF's fenders, and it'll look pretty damn flush lowered?
Old 08-13-13, 05:43 PM
  #37
shyguyF
shyguyF's Avatar
So...?
Agree +35.Do 255/30 almost equal with the stock tires in diameter.If you want to protect the rims go with Bridgestone Potenza RE050A
Old 08-13-13, 05:51 PM
  #38
ROK
ROK's Avatar
Sorry to sound like a broken record, but you guys seriously feel that this setup won't rub when lowered like so with the chunky Michelin Pilot Super Sports?
Final final specs:
20x9 ET35, 245/30 MPSS (255/30 not avail)
Started with:
If it all checks out when I get it in 10 weeks, I owe you guys a bottle!
Old 08-13-13, 06:05 PM
  #39
Murph145
Murph145's Avatar
Yea should be fine that's what I'm running but with nitto invos so just depends if the tires are a lil wider with michelins but should be good
Old 08-14-13, 01:51 PM
  #40
ROK
ROK's Avatar
There's no way this sucker hasn't been rolled or trimmed (11" ET52 on 295s)
Appreciate the feedback, but this is just too aggressive or flush in my eyes so going to stick with these specs:
20x9 ET39, 245/30 MPSS
20x10.5 ET49, 285/25 MPSS
Old 08-14-13, 03:05 PM
  #41
Murph145
Murph145's Avatar
here is my adv same offsets 20x11 +52 running nitto invos lowered on Tien HTech Springs no rubbing what so ever no fender roll and no issues. Each tire is different so he most likely has a different tire manufacturer.
If I go 305 on the nittos then I will have to shave the rear fenders
If you want to be safe go ahead nothing wrong with that
Old 08-14-13, 03:33 PM
  #42
ROK
ROK's Avatar
we're speaking in millimeters and half inches here anyways! pilot super sports are chunkier than nitto invos. thx for all your help!
Old 08-14-13, 04:01 PM
  #43
MK4Sup_isF
MK4Sup_isF's Avatar
You want aggressive drop with no gap, wider fitment PSS, and perfectly flush but refused to shave/roll your fenders. You can't have everything above!! How are you going to get away from hitting the fender lips, since they are still stock, when the suspension is compressed?????? Give up flush and "zero" gap if you don't want to mod your fenders, plain and simple!!
Old 08-14-13, 04:39 PM
  #44
Murph145
Murph145's Avatar
^ good wording
Old 08-14-13, 04:54 PM
  #45
ROK
ROK's Avatar
Because it's been done time and again (to state the obvious).
E46 M3 on 19" BBS LMs (IIRC 10.5s in the back). Carrera 4S 19x12s. GT3 19x12s. All lowered except the GT3 which is at the perfect height stock. No fenders nor trim alike molested. Why? To state the obvious, again, because widths, offsets and tire sizes were well thought out.
This isn't rocket science, though it sometimes felt like it with the ISF given how few people actually run properly fitting wheels since in the JDM crowd it feels like they're really into the "stanced" or poked out look with stretched tires. Just new to it all. Sorry if this is a bit off target for the group here.
Quick Reply: 20" wheel/tire fitment help
