Alignment after header install?
I'm scheduled to get my Sikky Headers installed this thursday...cannot wait! From what i've seen, the front suspension and assembly is removed to do this install. Is it recommended to do an alignment afterwards?
not true. if your mechanic know what hes doing.... an alignment is not needed. my mechanic has done about 6 isf header installs where no parts were touched to induce an alignment. i did an alignment check before and after my header install just for kicks.... no changes at all.
ill agree to disagree . like i said with my F , an alignment check was done before and after with no change. no sense in doing /paying for an alignment if the mechanic knows what hes doing. periodically....yes i agree but many F owners are under the impression that an alignment must be done after header install. this is not true. ill draft up a diy for the method used to install headers ,safely, and does not disconnect any suspension parts or any parts that would mess with the alignment...
Legender
05-24-13 03:39 PM
