Driver's side headlight issue
Old 03-05-13, 10:33 PM
rc2o6
rc2o6's Avatar
Exclamation Driver's side headlight issue + lowered on Teins
Hey everyone,
Earlier this evening, I noticed my driver's side headlight (low beam) was off. I flipped the switch (off/on) and the low beam would come back on for a couple minutes before going back out.
I checked the fuse in the engine bay, looks okay. I opened the low beam dust cover and twisted the actual bulb off and on, harness/cable looks undamaged. No CEL's or error messages.
I'm guessing it's a faulty bulb or ballast? If so, could my non-lexus extended warranty apply to this fix? My car currently has ~76,000 miles and it increases as she's my daily driver
What do you guys think? I plan to take it to the lexus dealership tomorrow or whenever they can fit me in with a loaner car.
Note 1- I do have jdmtoy's led drl kit hooked up but the wires don't seem to interfere from what I can tell.
Note 2 - Lexus replaced my ML subwoofer about 7k miles ago using my non-lexus extended warranty, i just had to pay the $100 deductible. Total cost was $625 to replace the sub
Note 3 - I just put on Tein H-tech springs on the fronts 2 weeks ago, any possible coincidence...
Here's a video for reference - bulb shuts off at 1:19
I also searched the forums and found a few similar threads:
https://www.clublexus.com/forums/is-...h-all-iss.html
https://www.clublexus.com/forums/is-...ssue-help.html
https://www.clublexus.com/forums/is-...s-one-out.html
https://www.clublexus.com/forums/is-...light-out.html
My F lowered on Tein H-tech springs on the fronts
Old 03-05-13, 11:48 PM
Sello
Sello's Avatar
Your bulb is toast. Same thing just happened to me.
Old 03-06-13, 11:58 AM
iH8RICERZ
iH8RICERZ's Avatar
my passenger side is doing the same as well... once you start noticing some discoloration, it usually means the bulb is at its end of its life. Just get a new D4S bulb
Old 03-06-13, 02:18 PM
RC5000
RC5000's Avatar
As others have said, the bulb has reached end of it's life.
You should replace them both if you dont want your bulbs to be different colors, the bulbs color temperature changes over time and a new one will appear more yellow than the old one.
You can pick up two Philips oem bulbs on Amazon for around $80.
Old 03-06-13, 03:20 PM
iH8RICERZ
iH8RICERZ's Avatar
OK, I feel foolish for asking, but I just removed all the plastic coverings and peaked into my passenger headlight section, but didn't see anything obvious to remove, open up, unplug, etc. I just got my garax bulbs in and wanted to replace my OEM's.... I know replacing this low beam HID bulb shouldn't be rocket science. Any help or suggestions? Space looks really limited and tight back there to even fit my hand in the available space
Old 03-06-13, 03:24 PM
rc2o6
rc2o6's Avatar
Thanks for the input. After further review, I wanted to test the bulbs so I pulled them out and swapped them earlier during my lunch. Looks like I have a bad bulb.
I just ordered 2 Phillips D4S bulbs from Amazon shipped overnight so I'll have them tomorrow. Total cost was $114. I wanted to replace both bulbs so the color isn't too off. Still better than the ~$175 per bulb I was quoted from my local Lexus dealership.
Thanks again
Old 03-06-13, 03:27 PM
rc2o6
rc2o6's Avatar
This thread says it all: https://www.clublexus.com/forums/is-...hid-bulbs.html
Old 03-06-13, 03:43 PM
iH8RICERZ
iH8RICERZ's Avatar
Originally Posted by rc2o6
This is EXACTLY what I needed! Thought it was a 30 second job, but I guess it requires the use of some tools. Thank you!!!!
Old 03-06-13, 04:29 PM
ISFpat
ISFpat's Avatar
Thanks again
Isnt one phillips bulb atleast ~$110 each??
Old 03-11-13, 11:43 AM
rc2o6
rc2o6's Avatar
Update
I ordered 2 Phillips D4S bulbs from Amazon. Got them last Thursday and installed both of them right away. Problem resolved.
Total cost was $114 shipped overnight (I have amazon
The bulbs I got from Amazon.com -
Amazon Amazon
Old 03-19-13, 09:55 PM
RDIS250AWD
RDIS250AWD's Avatar
wassup roger u found me on CL haha. Hope u get ur headlight fixed or maybe upgrade to a 2012 set =)
1Putt
02-19-24 10:43 PM
sallydrive
05-30-13 09:53 AM
randomwalk
12-01-11 11:07 PM
cm09578
IS F (2008-2014)
04-21-11 07:33 PM
bearbrew
RX - 1st Gen (1999-2003)
03-01-10 01:20 AM
Quick Reply: Driver's side headlight issue
