Exhaust question
Old 09-12-12, 03:13 PM
2ndGF
2ndGF's Avatar
Sweet! Good to hear your problem is taken care of!
Old 09-12-12, 04:07 PM
Meanstreak
Meanstreak's Avatar
Originally Posted by PhiDeltBee
Got this installed last night and all rattles are gone. Happy camper!
Did you end up getting a good price?
Old 09-12-12, 07:41 PM
PhiDeltBee
PhiDeltBee's Avatar
Ehh, $60. Easy come easy go. It's fixed and I'm happy.
I actually found out I had a spare in storage after I bought it.
Old 09-15-12, 06:28 PM
VtotheJ
VtotheJ's Avatar
I don't have any rattles besides the straight pipe occasionally hitting the back of the exhaust diffuser... regardless I slid underneath the car and snapped a pic to make sure my donut gasket was in there...
Old 09-16-12, 06:57 PM
SlowAsF
SlowAsF's Avatar
u should have reused the spring bolts, they are better and wont lossen up on u later.
Old 09-17-12, 03:40 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
The springs aren't there to keep it from loosening, they're there to keep the bolts from breaking under repeated thermal stress.
The owner of the rig in the picture is really introducing a great opportunity for failure by removing the springs.
Old 09-17-12, 07:39 PM
VtotheJ
VtotheJ's Avatar
I guess the spring goes between the rear exhaust section bolt and the pipe.....only issue is that the bolt may not be long enough
Old 09-20-12, 10:35 AM
VtotheJ
VtotheJ's Avatar
When I got the straight pipes done I noticed that one side sits adjacent to the lower quad tip, and the other side sits adjacent to the higher one. The welds look good, but this isn't a problem right...
Old 09-20-12, 11:51 AM
PhiDeltBee
PhiDeltBee's Avatar
I think my straight pipes were cut just short enough not to actually touch the tips upon moving. About those springs, I'm not sure what you mean by them not fitting the bolts? They worked fine with and without my donut gasket and kind of provide a bit of give in that section which you need.
Edit: Unless those aren't the stock bolts?
Old 09-20-12, 11:54 AM
PhiDeltBee
PhiDeltBee's Avatar
Not sure, but my bolts look like they may be longer? Those your stock bolts?
Old 09-20-12, 01:29 PM
VtotheJ
VtotheJ's Avatar
^^ After comparing with your pics, mine don't look like stock bolts. I'll take pics of the springs and bolts that was put in the box when I get a chance, those were the proper ones I think. I hope these hold up til my 30k service, which is in a few 1000 miles.
Old 09-20-12, 01:59 PM
PhiDeltBee
PhiDeltBee's Avatar
I wouldn't worry about 1000 miles, but I'd put them back in. Takes 2 minutes.
ZAM
RC - 1st Gen (2015-present)
03-11-19 07:09 AM
jhardy
11-11-16 11:10 AM
Toyboy250
Performance
12-02-14 04:49 AM
Sup2jzgte
Performance & Maintenance
03-27-09 04:28 AM
JohnGS4
04-06-05 12:59 AM
Quick Reply: Exhaust question
