sikky o2 simulator
Old 08-13-12, 01:39 PM
  #31
eoph
eoph's Avatar
When I first got the CEL, I got it checked and it was the low voltage for both o2 sensors, which led me to the o2 simulator, since the o2 sensors shouldn't be sending a signal to the ecu anymore.
Old 08-13-12, 07:21 PM
  #32
Super6
Super6's Avatar
My install guy was getting the low voltage reading. Turns out I was blowing a fuse cause of the passenger side o2sensor was touching-shorting. Prolly not the cause of your CEL but thought I would share just in case.
Old 08-13-12, 08:53 PM
  #33
eoph
eoph's Avatar
Which specific fuse? I remember pulling all of them out to check before and found nothing.
Old 08-13-12, 09:03 PM
  #34
RX7 RAGE
RX7 RAGE's Avatar
It's the A/F fuse on the driver side engine block.
Old 08-14-12, 07:37 PM
  #35
eoph
eoph's Avatar
So I used an odb2 reader and I got an extra code
P2241 bank2 sensor 1
P0136
P0137
P0156
P0157
I didn't hv the sensor 1 error before, I'm guess it's from the rubbing?
Old 08-15-12, 08:57 AM
  #36
eoph
eoph's Avatar
Is the bank 2 the passenger side or the drivers side?
I think it'll still be best to resolve the sensor 2 first, since the sensor 1 is brand new, so I at least know it's not faulty.
Old 08-15-12, 06:01 PM
  #37
NotnFsport
NotnFsport's Avatar
^^ passenger side is bank 2
Old 08-16-12, 08:35 AM
  #38
eoph
eoph's Avatar
Anyway to test the 'voltage' on the Sensor 1 and compare with what it should be?
Old 08-23-12, 08:33 PM
  #39
eoph
eoph's Avatar
So here's the update, I tried using vampire taps instead just like the pictures on page 1, since i'm out of ideas. And it did make a difference! except now it says the voltage is high . So what does that mean? When i went to canadian tire to buy those taps, there were blue and red ones, i bought the blue since it matched the picture, should i try red?
I also tried inspecting the bank 2 sensor 1, and it is very close to the car but not touching, like everything on the header. I tried just moving the wire with my hand a little. Then now I'm getting more errors that say it is rich?
Would changes to sensor 1 and 2 affect each other? Or can I attack them separately no problem?
Old 08-24-12, 07:03 PM
  #40
eoph
eoph's Avatar
So I know why the ecu complains about the voltage being too high, it is because the voltage no longer drops back down to 0, it stays at a constant 1.35. Does this mean the simulator is broken? Where can I get another one? JE Import Performance doesn't respond to me.
Old 08-24-12, 08:40 PM
  #41
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
^^^^Contact PPE, they will supply you with one. The cost is around $100.00.
Lou
Old 08-30-12, 06:32 PM
  #42
eoph
eoph's Avatar
So I had my frd looked at the wiring done by myself with the vampire taps, and basically it was at high voltage because the wire wasn't thick enough to be penetrated by the taps. He redid the wiring for me and it seems to work.......Until I go driving the car hard.
I'm getting a P0137 and P0156 now.
PO137 Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2)
P0156 Sensor Circuit Malfunction, Bank 2 Sensor 2
So both sides seem to have different errors........Is the g force on the o2 simulator moving it enough that it's causing those errors? Or is the 3 way wiring not twisted evenly enough that it's giving different errors for each sensor?
Another thing to note is that driving home before my frd redid the wiring I was also getting
P0607 Control Module Performance
Old 08-30-12, 06:45 PM
  #43
Juanca
Juanca's Avatar
The more you try to fix your car, the more codes you get. As I said before it's time to take the car to the dealer and get the problem resolved. You may end up damaging some electronics on your car if you continue trying things on your own, at this point it's evident that you have no clue about what you're doing to fix your car.
Old 08-30-12, 06:50 PM
  #44
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,079 Likes on 2,472 Posts
I didn't want to be quite so direct, but Juanca is right. You're way over your head here.
Old 09-26-12, 08:32 AM
  #45
4everkidd
4everkidd's Avatar
Eoph,
any updates?
Winter is right around the corner, and an ISF without traction control is a recipe for disaster in Calgary.
Quick Reply: sikky o2 simulator
