Pic of your IS-F - RIGHT NOW!
Old 07-22-14, 11:13 PM
  #1651
I8ABMR
I8ABMR's Avatar
I think many many people are holding on to that one thread that was posted and just keep repeating the same thing over and over again. Spacers are used on track cars all the time. Even race cars !! The bottom line is a quality part installed the correct way will be safe.
Old 07-23-14, 07:34 AM
  #1652
GermanISF
GermanISF's Avatar
Old 07-23-14, 08:44 AM
  #1653
Reaper21
Reaper21's Avatar
Lol you guys need to calm down. I never said spacers are a problem. I've ran them (both kinds) on every car I've modified. All I said was that there was MORE of a chance of the ones with built in studs failing than ones without. And yes, this logic does make sense.
Old 07-23-14, 10:46 AM
  #1654
yjk1975
yjk1975's Avatar
This is the truth.
  #1655
ISFpat
ISFpat's Avatar
The spacers WITH built-in studs have the chance to fail since you are relying on the 5 nuts holding the spacer to the hub not to come loose.
What is your explanation for this? I'm not trying to argue but I've ran both and felt much more confident with bolt on spacers. How is there a chance of failure if the spacer is properly bolted/torqued to the hub?
Well with that logic, putting wheels on your car "have the chance to fail since you are relying on the 5 nuts holding the wheel to the spacer not to come loose."
Old 07-23-14, 11:10 AM
  #1656
Reaper21
Reaper21's Avatar
This is absolutely correct. If the lug nuts are not properly torqued, they could come loose while driving and the wheel could come off. This is what I am saying about the built-in spacers. They inherently have the CHANCE of failure since they rely on another variable - proper torquing of the nuts.
Do you and I have to worry about this? Obviously not since we do everything ourselves and know that we took the appropriate steps to make sure the spacers will not fail. But, since many people don't have the proper knowledge and know-how, they rely on shops to do the work [who themselves may not know what the hell they are doing with spacers].
Old 07-23-14, 11:14 AM
  #1657
ISFpat
ISFpat's Avatar
I agree, that is the downside of spacers is that another variable is added.. however thats the risk that is taken with spacers and if the user does not properly torque down the nuts to the spacer then issues can arise.
With that being said, I like bolt on spacers and I make sure I do multiple passes when torquing the nuts on the spacers.
Old 07-23-14, 12:19 PM
  #1658
shahir18
shahir18's Avatar
Old 07-23-14, 12:29 PM
  #1659
Vervish
Vervish's Avatar
^ badass...
Old 07-23-14, 01:14 PM
  #1660
LexusISF19
LexusISF19's Avatar
you have B2designs 15mm spacers (x2) for 220$?
Attached Thumbnails Pic of your IS-F - RIGHT NOW!-image-1096953409.jpg   Pic of your IS-F - RIGHT NOW!-image-3257641143.jpg
Old 07-23-14, 01:43 PM
  #1661
speeddem0n
speeddem0n's Avatar
Last week... dirty but cant tell in the pic
Old 07-23-14, 05:06 PM
  #1662
Marn
Marn's Avatar
Old 07-23-14, 06:08 PM
  #1663
Rickna
Rickna's Avatar
Sweet. What did you use to blackout the window trim?
Old 07-23-14, 06:12 PM
  #1664
shahir18
shahir18's Avatar
What's you tire specs / size?
Old 07-23-14, 06:45 PM
  #1665
Marn
Marn's Avatar
its vinyl wrapped.
Quick Reply: Pic of your IS-F - RIGHT NOW!
