Which oil?
Old 03-01-12, 07:34 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,080 Likes on 2,472 Posts
Mobil 1 5w-30. You can see my results with 12k mile OCI in the Blackstone thread.
The Supra always gets Red Line 10w-30. Turbo engines are hard on oil.
Old 03-02-12, 04:17 AM
DCoolBeans
DCoolBeans's Avatar
Lubuxracer: you changed out your filter though at the 6k mark, right? How much oil came out from the filter housing?
Old 03-02-12, 05:17 AM
js619858
js619858's Avatar
Only the best for ISF!!! Shell or Chevron.
js619858
js619858's Avatar
You don't want to feed your body with fast food and fat, so treat your ISF the same!
Old 03-02-12, 05:58 AM
wpb_shaun
wpb_shaun's Avatar
Mobil 1 all the way!
Old 03-02-12, 06:25 AM
madastep
madastep's Avatar
i use mobil 1 as well, and our car takes 10.5 quarts ish... so the expense is usually in volume. ugh
Old 03-02-12, 11:37 AM
dano9258
dano9258's Avatar
So it seems Mobil 1 is the best option. Nobody really stated weather its alright to mix that with Shell gasoline....
Old 03-03-12, 04:34 PM
Autobacs
Autobacs's Avatar
Dont matter what combo of oil and gasoline you use.
As far as gas, cant go wrong with Shell, 76, or Chevron.
Old 03-03-12, 06:50 PM
ISF4life
ISF4life's Avatar
Mobile 1 full synthetic .
Old 03-03-12, 07:22 PM
ISFSteve
ISFSteve's Avatar
Amsoil in all my vehicles
Old 03-03-12, 07:43 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Exclamation
Actually our IS-F motor takes 9.8 Qts w/ new filter.... Probably closer to 9.5 Qts if you don't wait for the slow stream of oil to stop when draining..
10.5 quarts is an overfill for sure....
Joe Z
Old 03-03-12, 07:52 PM
Joe Z
Joe Z's Avatar
Thumbs up
One of my saved posts....
Originally Posted by Joe Z
I just use the basic dino oil - Mobil 5w30 (Clean 5,000)
Walmart has the 5 Qt jugs ready to go for like $12 bucks each..
It didn't come with synthetic from the factory
2 - 5 Qt jugs of regular Mobil 5w30 = $ 27
1 - Lexus IS-F Oil Filter #04152-51010 = $ 8
1 - Lexus Drain Plug Gasket = $ .90
Labor = Priceless
Total Cost for ME every 5K Miles is approx. $36
~ Joe Z
Old 03-03-12, 08:28 PM
ming15237
ming15237's Avatar
BG synthetic oil is the only oil that will ever go into any of my engines. http://www.steffysgarage.com/downloads/BGChart.pdf it is the only oil too pass the very chalanging tfout test.
Old 03-03-12, 09:13 PM
Endgame
Endgame's Avatar
Royal Purple, as I understand, was causing 350/370Z engines issues. I used Redline with my 370Z when I had her. The big debate on the 370Z forum was Mobil 1 or Redline. Redline won out being the better buy.
Does anyone use Redline? Is it worth paying more for it than the Mobile 1? I think the Z06s come with Mobil 1 standard.....
Old 03-04-12, 08:29 AM
jkeifer3
jkeifer3's Avatar
Default Two Thumbs Up For Mobil 1
I use Mobil 1 0w-40 even though it hasn't been really cold enough to benefit from the cold-flow characteristics of this oil.
Quick Reply: Which oil?
