Still drifting to the right
Old 02-16-12, 08:12 AM
VtotheJ
VtotheJ's Avatar
Originally Posted by DCoolBeans
^ yeah I feel ya. We all paid a nice chunk to have this car so why not.
Is this a warranty issue or ?
Not a warranty issue, it's an alignment issue so it would be covered if you were under 1yr/20k. It sucks to hear that even the '10 F's are having this issue. There are a lot of things you can do (which I already got done), I would get them done at the dealer since this problem is specific to the F:
1) have them swap your tires to rule out conicity issues
2) get the rear/front subframe adjusted until the car tracks straight on a FLAT road
3) get alignment again
^^^ As mentioned I had these done and my car still pulls right, slightly but noticeably. I was offered to get my caster brackets changed (adjusts caster), but will run me ~$400:
- $250 for parts and labor
- $130 for alignment
- $20 tax?
I'm holding off since another member mentioned his car pulled even with these brackets in. I'll live with it until I need an alignment, which is when I will get the brackets put in.
Old 02-16-12, 08:27 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
These tires have less than a month on the car. Do you want me to measure the rear widths even though they are the same tire dimensions?...
Not width, circumference. Put a tape measure around the tire and measure it. They should be nearly identical. This is easy to do with the tires off, but next to impossible with the tires on the car.
Old 02-16-12, 08:57 AM
Fitment Factory
Fitment Factory's Avatar
Danny,
Sounds to me like radial pull.Try swapping your front tires from right to left or vice versa to see what happens and if the issue gets fixed. Happened to use recently on a car we did and went through the hole process and came to find that it was just the tires. Lobux has pretty much the same idea. If you want pass by the shop and we can try it out.
Gio
Old 02-16-12, 09:49 AM
DCoolBeans
DCoolBeans's Avatar
Originally Posted by Fitment Factory
Danny,
Gio
Thanks Gio, I'll hit you up today to see if I can swing by tomorrow. If this doesn't clear it up then imma call up Miami Chassis and see if they can adjust the sub frame :/ . I paid for a 3 yr alignment at a shop, I can get it realigned as many times as I want.
I'll also measure the wheel/rims. Yes the tires are all the same brand, I mounted this combo less than a month ago.
Old 02-16-12, 10:21 AM
iH8RICERZ
iH8RICERZ's Avatar
Noticed my F has the same issue as well.... it doesn't pull hard, but enough for me to notice if I let go of the steering wheel. I'm going to try swapping the fronts like some of you have recommended and go from there.
Old 02-25-12, 11:31 PM
Kingkrs
Kingkrs's Avatar
kinda glad to see I am not alone. My 11 that I have had since 1 Jan has 1,700 miles and it pulls slight right as well. I thought it was road crown but it even happens when I am on the left side of the highway or while on the relatively flat side streets near my home. Really puzzling to see this. You think Lexus would have a TSB or something done about this. I really noticed this when I took the car on a short road trip. Does anyone know if there has been acknowledgment from Lexus concerning this?
Old 03-12-12, 10:43 PM
Kingkrs
Kingkrs's Avatar
Old 03-13-12, 09:09 AM
DCoolBeans
DCoolBeans's Avatar
^ I'd liketo know this aswell before I go to the dealership
Old 03-13-12, 09:24 AM
staman
staman's Avatar
I went to my Lexus dealership yesterday to talk about it and they had no clue what i was talking about. When I talked about re-aligning my sub frame, again they had no clue what i was talking about. The shop forman's exact words were "The sub frame on an F can't be adjusted". I told him that's funny because I know of about 25 people on clublexus that have done it... I then called a highly recommended alignment shop and got the same result. They said they didn't know how to do that if it didn't involve toe/camber adjustments..He DID know what a caster bracket was and said he could install them.. Gonna pick those up today when i pick up my PSS 275's for the rear...
Old 03-13-12, 09:36 AM
CCColtsicehockey
CCColtsicehockey's Avatar
I am having this same issue with my 08. No one has seemed to be able to fix it. I have pretty much just given up.
Old 03-13-12, 10:00 AM
UCrazyKid
UCrazyKid's Avatar
ISX50s cannot have the subframe adjusted, they are pinned with dowels. The ISF can, but most dealers do not know this. The ISF subframe is different (go figure). Have them check. It probably only needs to move a few millimeters to correct, equal caster and camber is needed left to right to solve the problem. Ask me how I know.... I had the same problem and it took ~6 trips to get it right.
As far as getting the dealer to do it, go luck. Lexus customer service is for *****. have a look at my other thread about my nightmare with Lexus and it is STILL not resolved.
https://www.clublexus.com/forums/car...t-74-days.html
Old 03-13-12, 12:05 PM
Evil Teo
Evil Teo's Avatar
same here, it took quite a while for them to get it done right. they didn't even know what was causing it until I suggested the brackets. from looking at my recent alignment sheets it looks like the brackets was taken off. im gonna check with my dealership cuz they installed it and somehow now they were taken off.
Old 03-14-12, 07:22 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
No, the subframes are identical across the entire range. There is no reason you could not adjust the subframe on any of the 2IS.
Code:
Model	Production Date	Engine	Transmission	Trim	Body	Door
IS250	2010.08-	4cyl 2.5L	MTM		SED
IS250	2010.08-	4cyl 2.5L	ATM		SED
IS250	2010.08-	6cyl 3.5L	ATM		SED
IS250	2008.08-2010.08	4cyl 2.5L	MTM		SED
IS250	2008.08-2010.08	4cyl 2.5L	ATM		SED
IS250	2008.08-2010.08	6cyl 3.5L	ATM		SED
IS250	2005.08-2008.08	4cyl 2.5L	MTM		SED
IS250	2005.08-2008.08	4cyl 2.5L	ATM		SED
IS250	2005.08-2008.08	6cyl 3.5L	ATM		SED
IS CV	2009.04-	4cyl 2.5L	MTM	250C
IS CV	2009.04-	4cyl 2.5L	ATM	250C
IS CV	2009.04-	6cyl 3.5L	ATM	350C
IS350	2008.08-2010.08	4cyl 2.5L	MTM		SED
IS350	2008.08-2010.08	4cyl 2.5L	ATM		SED
IS350	2008.08-2010.08	6cyl 3.5L	ATM		SED
IS350	2005.08-2008.08	4cyl 2.5L	MTM		SED
IS350	2005.08-2008.08	4cyl 2.5L	ATM		SED
IS350	2005.08-2008.08	6cyl 3.5L	ATM		SED
IS F	2007.12- 	8cyl 5.0L	ATM
GS350	2007.09- 	6cyl 3.5L	ATM
GS350	2007.09- 	8cyl 4.6L	ATM
GS350	2005.01-2007.09	6cyl 3.5L	ATM
GS350	2005.01-2007.09	8cyl 4.3L	ATM
GS350	2005.01-2006.07	6cyl 3.0L	ATM
GS430	2007.09-	6cyl 3.5L	ATM
GS430	2007.09-	8cyl 4.6L	ATM
GS430	2005.01-2007.09	6cyl 3.5L	ATM
GS430	2005.01-2007.09	8cyl 4.3L	ATM
GS430	2005.01-2006.07	6cyl 3.0L	ATM
GS450H	2007.09-	6cyl 3.5L	ATM
GS450H	2006.02-2007.09	6cyl 3.5L	ATM
GS460	2007.09-	6cyl 3.5L	ATM
GS460	2007.09-	8cyl 4.6L	ATM
GS460	2005.01-2007.09	6cyl 3.5L	ATM
GS460	2005.01-2007.09	8cyl 4.3L	ATM
The only odd thing is this part number is superceded by 51201-30140 across all models as well.
Old 03-15-12, 08:44 AM
staman
staman's Avatar
So if I go back to my Lexus dealership what should I say to them regarding the sub frame adjustment. I'd like to tell them exactly what has to be done so they don't think i'm full of ****
Old 03-15-12, 07:12 PM
Kingkrs
Kingkrs's Avatar
I went in and had my alignment corrected. it was out by a little bit. But that does not seem to fix the drift right. I talked to the service guy about adjusting the subframe and he looked at me like I was crazy. I told him that others have had it done to correct the problem but he was firm in his stance that it cannot be. I am going to go back and have them put it on the rack again to see if it is out again. I still don't think that is the problem though. After this does not work I am going to bring it up with the service manager and see where that gets me. if that does not seem to work then maybe the twitter option may work and or some other means.
I really have to think Lexus has some kind of clue about this. This just can't be an issue that is out there flapping.
Quick Reply: Still drifting to the right
