Radar Detector
Old 11-22-08, 02:47 PM
cm09578
cm09578's Avatar
Default Radar Detector
Anyone have a radar detector on the F? If so what kind?..thanks
Old 11-22-08, 03:22 PM
DRE1615
DRE1615's Avatar
K40 front and rear. No regrets
Old 11-23-08, 04:33 AM
zakizaki
zakizaki's Avatar
Valentine-1; the best there is.
Old 11-23-08, 07:18 AM
phantax
phantax's Avatar
Escort 9500ix
Old 11-23-08, 09:34 AM
BigMikeISF
BigMikeISF's Avatar
V1...if your thinking about getting one, I'd run a search on here and you'll find tons of info about them
Old 11-23-08, 11:21 AM
foup
foup's Avatar
9500ix which I connected to the mirror using an ultra-thin black wire (spent hours doing it because I wanted the connection at the mirror to be soldered on the connector and using small wires on RJ45 jack is not easy task).
The wire I used was from an earphone (you know those are extra tiny).
9500ix is always quite during my commute and this is what I wanted. It's mounted unobtrusive behind the mirror and therefore its efficiency to detect rear LIDAR (point and shoot Laser gun) is probably near to zero (tinted windows don't help) but that's OK since cops rarely use LIDAR from the rear and since LIDAR is pretty much undetectable "in advance" anyway, even from the front.
Old 11-23-08, 11:35 AM
cm09578
cm09578's Avatar
How much did this cost you? Where do you buy?
Old 11-23-08, 12:01 PM
foup
foup's Avatar
$499 directly from Escort, a while ago.
Old 11-23-08, 05:42 PM
Lexicated
Lexicated's Avatar
I have been reading about them as well. Funny the top two seem to be V1 and Escort 9500ix in about every forum I have been on (and the first ones mentioned here). V1 has it's loyalist as well as the Escort Line. I live in VA so it's not for me (STI probably the best for VA).
Seems the GPS (speed and traffic light camera built in database with learning) and less false alarms seem to be the big plus for the 9500ix
V1 seems to have a greater range, but by small margin (plus the arrows and bogey counter) but many false alarms although there are adjustments to help with that.
The V1 is about $100 less. I was considering this as a gift for my father who is retiring. The 9500ix seems to be a little more complicated to "learn". I think many F owners would lean toward the 9500ix (blue screen Ha Ha). For a retiree, probably the V1 would be easier to use. I don't have either, never used any, and this is just based on some quick reading off the web.
Old 11-23-08, 08:16 PM
suicidesam
suicidesam's Avatar
foup why don't you mount it to your rear-view mirror for a cleaner look...here's mine
https://www.clublexus.com/forums/sho...d.php?t=328039
Old 11-23-08, 08:29 PM
timeToy
timeToy's Avatar
I have mine just like foup
https://www.clublexus.com/forums/sho...d.php?t=384179
Old 12-09-08, 11:15 PM
ggzoa
ggzoa's Avatar
K40 plus diffusers. Haven't been pulled over in 2+ years. Worth every penny.
Old 12-11-08, 12:55 PM
smoothLEX
smoothLEX's Avatar
I have a passport and a v1, and I like the v1 hands down. The Passport is for my wife's car.
Old 12-11-08, 03:21 PM
passnu2
passnu2's Avatar
i just got the same radar and mounted in the same spot, no hardwire came with it so I need to get one and will wire up in the same spot whta do you think so far? I sold my V1 and just got this from the advice of a local member. Got it for a steal also.
Old 12-11-08, 07:47 PM
BigMikeISF
BigMikeISF's Avatar
I just did the same thing (sold the V1 and got the 9500xi)! That's where I just got back from actually haha I'm going to order a hardwire and get it up this next week! I haven't used it enough but the red light camera aspect is awesome and its quieter then the V1 but I haven't used it enough yet to say one or the other is better
Quick Reply: Radar Detector
