Really dumb question
Old 11-03-08, 06:06 PM
VelvetBlue
VelvetBlue's Avatar
Default Really dumb question
How do you change the clock to account for the time change? On my RX400h you hit the INFO button and there is a button that says Adjust Clock. But on the IS F when I hit INFO there is no adjust clock. Then on the MENU under setup I see the Time Zone setting. But I tried Daylight Savings both on and off and it has no affect on the time displayed on the clock. I'm so confused!!!! And too lazy to read the manual.
Old 11-03-08, 06:14 PM
dkaplan435
dkaplan435's Avatar
Just hold the hour (or minute) button. It will eventually increment.
Old 11-03-08, 07:25 PM
BigMikeISF
BigMikeISF's Avatar
^^That's what I did this morning to change it I didn't know there was even a way to account for daylight savings time!
Old 11-03-08, 07:28 PM
DRE1615
DRE1615's Avatar
They didn't add that feature in the ISF because it added to much weight to the car. HAHA just kidding. Not really sure about what you're referring to. I just manually changed mine. Good luck
Old 11-04-08, 04:37 PM
Juanca
Juanca's Avatar
IIRC go to the NAV settings and change the time zone, that's what I did last Sunday.
Old 11-04-08, 05:39 PM
larrysb
larrysb's Avatar
Yeah, I noticed that too.
My wife's RX400h gets the time from the GPS signal. All you got to do is tell what timezone you want it to display.
The ISF clock is just a plain old clock, not hooked up the GPS at all. Weird, you'd think it would be the same. I like the GPS sync feature, means the time is always accurate.
Old 11-04-08, 06:04 PM
Juanca
Juanca's Avatar
I don't think so, I believe the clock is tied to the NAV system. On the NAV settings you change time zone (even though it should know already from your position) and daylight savings, but not time. When you change the time on the clock it changes as well on the NAV.
Old 11-04-08, 06:06 PM
VelvetBlue
VelvetBlue's Avatar
Thanks for the responses. I did the hour button thing since the day light savings setting in the time zone setup didn't do anything.
Old 11-04-08, 06:07 PM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
Our navi tells time?
Unless the ISf is different, you have to change it manually, the clock isnt in sync with the GPS. I think the time zone setting you are talking about is the region settings.
jarm
03-20-19 04:58 PM
sscarbuff
GX - 1st Gen (2004-2009)
12-10-17 03:42 PM
Kazabet
07-04-09 09:34 AM
curious67
06-25-06 11:09 PM
Quick Reply: Really dumb question
