.150 amp draining while off
I am not sure if this normal or not but I would think there are few circuits and sensors that remain active even with the car off. Presumably the remote key approach circuitry and maybe a some other could account for this. I don't think150mA should be much of a burden on a fully charged healthy car battery.
This was common back when I worked for volvo. However, if it's remaining even after the vehicle was asleep, then we would diagnose by narrowing it down to which circuit by pulling and re-installing fuses with your meter hooked up until you saw the draw go away. Much more common on older cars, although there's always a risk of a module communicating when it should be asleep.
Tech Info Resource
How far away was the key when you did this? If the key is within 5 meters, it will be communicating with it.
andy2003si
01-24-05 10:33 AM
TwentyTen
12-10-03 08:58 AM
