Easy Fixes for Small Issues (hopefully?)
Hey guys, I have had my 08 USB ISF for over a year and a half now, and some of the smaller flaws/defects have started to annoy me. I was hoping some of you might know of easy fixes for these little issues (they may seem insignificant, but can you blame me for wanting my car to be perfect, regardless of its age?)
1. The gasket in the lower driver side corner of my windshield is deteriorated and pieces of it fall apart just from running your finger against it. Is that part easy to replace? or would I have to really take a lot of things apart? I will be providing pictures as soon as I get a chance to take some.
2. Sunroof seems to rattle a little when its fully open or slanted open, particularly when going over bumps (I know this is a pretty common issue and not a big deal, but I was hoping some of you had found a simple fix for this)
3. My drivers door, despite my best efforts to NEVER put any weight on it, seems to be mildly misaligned? it opens and closes without any issues, but when im driving (again, particularly when going over bumps) it makes some jostling noises.
4. My passenger side front window REALLY sounds like its struggling when I roll it up and down.
5. The cargo pass through hatch between the trunk and rear seats wont latch or stay closed... it just pops right back open... should I just replace this? or is there an easy way to fix it (aside from just taping it shut ... which i would rather not do)
6. Last time I washed my car, I noticed that my tail lights had a little bit of moisture in them and a dead spider or two in each of them... not sure how they got in there, but is it easy enough to get them out?
7. Not really sure how to describe this one... and there doesn't seem to be any real cause, or trigger for it (aside from, potentially, temperature changes causing things to expand/contract?). When I am driving and my car has been running for few minutes, sometimes I get a rather loud popping noise that seems to come from behind the dash. Its not from going over bumps or anything. It seems really randomly timed. Anyone else have this issue or have any ideas what it could be? I am hoping when the lexus dealership finally calls me to come in for my takata airbag recall, they can fix this issue as well... but I wouldn't even know how to explain it to them, and due to its random nature, it would be hard for them to replicate.
Thanks for your time, guys. I greatly appreciate any advice/experiences you could provide.
Thanks, newgsman. I think mine is seating properly... just horribly deteriorated and literally crumbling to pieces (which is odd, because the passenger side looks fine). I am attaching a picture of what im talking about:
I had an issue where one of my rear doors would chime "open" when cornering aggressive in the opposite direction. I stuck an adhesive felt piece over the sensor to put extra pressure on it. If your door rattles, you could see where it's contacting and shim it out with something soft.
This is the only issue I had with mine. This is normal wear and tear as it also depends on climate.
I bought mine from Lexus $45 ea if I remember correctly and had them installed when I bought a new windshield.
https://www.clublexus.com/forums/is-...placement.html
Slightly off topic but I there a way to protect the rubber around the windshield? Just got mine replaced, Ive heard aerospace 303 coud help with it? Cant really help with the rest of these isues as my car doesn't really have them, sorry OP
