HELP with 20's
HELP with 20's
I've been searching and haven't found the right answer
Im running stock suspension and Im looking at a square set of 20x10.5 +42 with 275/30r20. I may lower the car in the future but not definite.
Am I going to have any issues with these fitting the front? I will roll the fenders if I need to to prevent rubbing.
I'm at stock height and have a square setup of 20x10 with 275/30/20 tires. The rear is rolled flat and the fronts fit slightly. I only rub (front and rear) on huge dips other than that it's fine. I'm not sure if it would look stretched or not but I would recommend 255 for the fronts.
I just bought my F with this setup so can't speak too much to it but I have 245/30-20 on the front and 285/25-20 in the back. No issues unless I have 2 grown adults in the back seat, I get some rubbing in the back when I hit bumps. Wish I had a pic from the rear, it looks tough with the 285's
They didn't fit....the fronts were hitting the strut
They may have with a small spacer like a 5mm but I forgot them at home.....oh well, on to the next
ScKcBc
01-15-10 10:09 AM
