Questions on BC coilovers/rubbing
Old 10-12-16, 12:06 PM
nks979
nks979's Avatar
Default Questions on BC coilovers/rubbing
So its finally time to replace shocks, one of them finally bit the dust - did more hunting in the cars records and it turns out they are the original ones from when the car was brand new Going to order some BC coils and was wondering if anybody had rubbing with 245/35/-275/30 tire setup on stock 08 wheels, wasn't able to find any threads on if it rubbed. Also thinking of putting on some 15mm HR spacers as well if they won't rub, any input on this setup? Hoping I don't have to roll fenders and wanted to know before i decided on spacers or not.
Old 10-12-16, 06:32 PM
N2LEX2L
N2LEX2L's Avatar
Exact set-up I had, with no rubbing at all at factory height. Not sure if the 15mm spacers will change that scenario.
Old 10-12-16, 07:00 PM
nks979
nks979's Avatar
Factory height or with BCs? Ive got nothing at stock height either but don't know if i will being lower by an inch in the front and .6 in the back.
Old 10-13-16, 05:07 AM
mikersoft
mikersoft's Avatar
It should be fine unless the offsets on '08 wheels are more aggressive than mine.. I'm lowered, and have 255/275 tires on '12 wheels with 15mm H&R spacers.. The only time the front tires rub is when turning the wheel in reverse, or when the suspension is fully compressed by a large bump or dip in the road. Pretty sure the rear tires never rub..
-Mike
Old 10-13-16, 06:23 AM
nks979
nks979's Avatar
Awesome, thanks mike, I think the '12 wheels have higher offsets then the 08s but I'll check. I know you track your car and If you have no issues then mine should be fine.
Old 10-13-16, 11:17 AM
JM Auto Racing
Sponsor
CL Vendor - Starter
JM Auto Racing's Avatar
With that setup you will not have rubbing issues with the BC Racing
__________________
Email:sales@jmautoracing.com
AIM: jmautoracing@gmail.com
www.jmautosports.com
1-855-998-8726
Old 10-13-16, 11:27 AM
Vervish
Vervish's Avatar
I have the same setup but 2011 wheels (same spec as 2008) - this is about as low as I can go without fender mods - mine would rub the fender liner in front if I got any lower. Running BC coils on 245/275 with 15mm HR spacers.
Old 10-13-16, 11:29 AM
iH8RICERZ
iH8RICERZ's Avatar
I'm on 245/35 and 285/30, BC coilovers with the Swift upgrade to 16k/12k. The only rubbing I get is if I'm going around a turn real hard/fast and there's a bump mid turn, I hear my wheel rub into my fender well for that split second. Besides that, no rubbing what so ever, even when its loaded down with my wife and kids in the car.
Vervish
Vervish's Avatar
This was the height I originally dialed in, and it rubbed.
Old 10-13-16, 11:32 AM
jspecvtec
jspecvtec's Avatar
Yeah 12 wheels more aggressive by 4 mm in rear
Old 10-13-16, 03:53 PM
nks979
nks979's Avatar
Wow that looks a lot lower than I expected, looks great. Is that really the 1/.6 drop from BCs?
And also thanks for the info everybody, its really helpful.
Old 10-13-16, 09:40 PM
DAng87
DAng87's Avatar
the BC coilovers are height adjustable, u can pretty much set it to the height u want
Old 10-14-16, 03:46 AM
Jz39
Jz39's Avatar
do you have camber or toe mods at this height? How does your alignment look? Your height looks perfect for what I would like to do.
Old 10-14-16, 06:26 AM
Vervish
Vervish's Avatar
No camber or toe mods, I am running Figs LCA bushings tho.
Camber is way off on all 4 corners - but I think it is less than - 3 degrees. That is not enough to affect tire wear. Toe is aligned to 0 degrees all around to eliminate/minimize tire wear issues.
Here is another angle..
Old 10-14-16, 06:35 AM
nks979
nks979's Avatar
Didn't know they were height adjustable, thats great - does it go all the way back up to stock height? And again thank you vervish, the car looks great.
Quick Reply: Questions on BC coilovers/rubbing
