Acceleration hesitation
Old 05-31-16, 10:01 PM
knshro13
knshro13's Avatar
Default Acceleration hesitation
hey guys,
I have a question. My 2012 ISF has this weird hesitation going on. On manual mode with Sport, I would try to accelerate pretty hard and around 5k RPM, it would bog down and hesitate. Almost feeling like it's choking. Has anyone felt this before?
Old 05-31-16, 10:05 PM
I8ABMR
I8ABMR's Avatar
I had the same thing when my AOS was loose. Do you have a catch can ? Or an intake with an oiled filter ?
knshro13
knshro13's Avatar
Also, I forgot to mention. This issue goes away when I restart the car. It's happened twice already.
Randomly comes.
Old 05-31-16, 10:17 PM
knshro13
knshro13's Avatar
Hey buddy, No I don't have am AOS. The car is bone stock. And the Oil filter is dry.
But i did read somewhere that an oiled filter does cause issues. I've reset the ecu and it has not happened yet but the occurrence was so random.
If the MAF was dirty, the issue should be consistent right?
Old 05-31-16, 11:22 PM
j3ff
j3ff's Avatar
I've had this issue on occasion as well but around 3-4K RPM. Never any hesitation above that so I just figured the car doesn't like being floored at low rpms..
Old 06-01-16, 08:37 AM
One2beH8ed
One2beH8ed's Avatar
I know this sounds stupid but you are turning traction off right? If you don't it will bog down until traction is caught.
Old 06-01-16, 12:58 PM
j3ff
j3ff's Avatar
Does anyone drive with it on? Jk. Yeah it's off. It's a very obvious bog when it happens; very similar to bogging a car in manual.
Old 06-01-16, 08:30 PM
knshro13
knshro13's Avatar
Not stupid at all mate. But yes I did turn off tc completely. Still happened. It's weird. When coasting on the highway, I'll put it in M mode, sport, and then punch the accelerator. When it gets to around 5k, the engine will choke and the rpm drops (while my foot is still pegged to the floor).
But anyway, i ordered an AOS, a new air filter, and got some electrical cleaner to spray the MAF. I'll see if it comes back.
Old 06-01-16, 10:34 PM
shyguyF
shyguyF's Avatar
You can buy 1 can of BG44K to clean fuel system and you will see the results
Old 06-02-16, 03:12 PM
knshro13
knshro13's Avatar
Thanks mate, that was next on my list. In fact, I was going to pull off the injectors and get them cleaned. But the issue isn't consistent. It's random. Should dirty fuel system show consistency?
Old 06-02-16, 07:08 PM
FinLIFE
FinLIFE's Avatar
I had something similar happen to me today. Floor the car off the line and from 5k to redline its almost like it was choking or like it was being held back..throw it in 2nd gear and tjres squealing and it moves. Best way i can describe it is if anyone has ever driven a honda before its almost as if "vtec" doesnt kick in. I unplugged the battery for a while i just have to go for a test run again
Old 06-03-16, 02:13 PM
knshro13
knshro13's Avatar
That was exactly what happened. At around 5k, it choked and the rpms began to drop. Restarted the car, and it went away.
Old 06-03-16, 03:21 PM
idoke1
idoke1's Avatar
Hard to say......it could the car pulling timing. Check to see if it goes away if you add some octane booster. Our gas in CA sucks.....
Old 06-03-16, 03:30 PM
Vervish
Vervish's Avatar
Check to confirm that your air box is sealed all the way around. I had a similar issue and it was because the dealer checked my air filter and did not properly close the box...it was open at the bottom.
Old 06-03-16, 04:02 PM
knshro13
knshro13's Avatar
Will that do it? It was under load so it makes sense. I do have a crack in the air box but it's pre-filter so I didn't think it would affect it.
I didn't think it would have an affect since that's before MAF.
Quick Reply: Acceleration hesitation
