Turbo isf
Old 05-09-16, 07:08 AM
Artem696
Artem696's Avatar
Default Turbo isf
Hi guys. I'm far from Russia. sorry for my bad english. tell me who do you isf turbo ??? how do I do and adjust?
Old 05-09-16, 07:24 AM
Artem696
Artem696's Avatar
what to do to drive less than 12 seconds on the 1/4 mile
Old 05-09-16, 07:29 AM
Biggu
Biggu's Avatar
12 seconds you only need intake, headers, exhaust and tune.
Boosted is not an option yet. RR Racing is working on a bolt on supercharger currently.
Old 05-09-16, 07:36 AM
Artem696
Artem696's Avatar
the whole problem is that no one knows how to adjust
Old 05-09-16, 07:40 AM
Artem696
Artem696's Avatar
show that it is better to buy a milking this
Old 05-09-16, 07:51 AM
MileHIFcar
MileHIFcar's Avatar
I'm guessing you mean tune the car by adjusting it?? The car can be tuned now and if someone or company wants to make a turbo kit they can now that the car can be tuned, but no company has stepped up to that challenge (though that would be awesome!).
Like Biggu said above RR-Racing is currently testing their S/C kit and should be released probably by the end of the summer with appropriate tuning to support the mod.
Old 05-09-16, 07:58 AM
Artem696
Artem696's Avatar
oooo it is perfect !!!! I understand that soon will be released a turbo kit?
Old 05-09-16, 08:11 AM
MileHIFcar
MileHIFcar's Avatar
No a supercharger kit from RR-Racing........ no one yet has stepped up to creating a functional Turbo kit with appropriate tuning yet...........
Old 05-09-16, 08:18 AM
fueler
fueler's Avatar
compression ratio is way too high on these engines to really make it worth while.
Old 05-09-16, 08:25 AM
Artem696
Artem696's Avatar
I think when you install s / c power will be around 550 horsepower. when this power would be 1/4 mile 11.5 seconds approximately
MileHIFcar
MileHIFcar's Avatar
Knowing that the F's compression ratio is indeed high I wonder if the motor can handle a low boost Turbo like 5-6 psi??
What's the difference in boost pressure when the S/C will be around I think the same boost if I recall
Old 05-09-16, 08:56 AM
Artem696
Artem696's Avatar
I wonder if I will be able to set up online?how many do you think will it all cost? I have the Audi A6 3.0 TFSI compressor magnachardzh worth $ 10,000, I think it is very expensive. What do you think
Old 05-09-16, 10:01 AM
ISF4life
ISF4life's Avatar
its only in Russia u need the turbo F to plow the snow
Old 05-09-16, 10:09 AM
Artem696
Artem696's Avatar
we sometimes warm))) and I am now in the far north, we -5 degrees Celsius
Old 05-09-16, 10:34 AM
Bigjon3475
Bigjon3475's Avatar
At about 5 psi above and beyond sea level atmospheric pressure you should see:
Supercharged stock: 475 whp
Supercharged with cat-back exhaust: 505 whp
Supercharged with full exhaust no cats: 555 whp
That's if enough fuel can be added.
At 7 psi above atmospheric pressure:
Supercharged stock: 515 whp
Supercharged with cat-back: 555 whp
Supercharged full exhaust no cats: 605 whp
Again that's if you can supply the fuel. Also, these are just rough estimates using 350 whp for stock, 375 whp with cat-back and 410 whp with full catless exhaust.
Seven psi might be pushing it on cars that are close or at seal level. Probably be alright to push 7 psi at 6,000 ft of elevation. Something we all should soon be finding out.
If you use 13 second 1/4 mile time for stock you essentially would have a mid to high 10 second car with 7 psi and full exhaust if you could get it to hook.
Quick Reply: Turbo isf
