Front wheel bearings IS F 2010
Need to replace my front wheel bearings. Does anyone know where can I find an after market replacement or any suggestions
Thank you for your reply. I read through and unfortunately there's no solid info to help my issue. I as well bought the Moog replacement and they where to short. Was hoping they came out with an after market by now
I used these guys when I did mine on my IS350, best price quick ship.
http://www.rockauto.com/en/catalog/l...le.com+URL+%2F
If you want the best go with Timken. Hope this helps
Received 1,058 Likes
No one ever provided it in the other thread...
The IS F front hubs are unique & specific to that model only.
Joe Z
Tech Info Resource
Poking around the web, it really does look like they should work, but again, we've seen a lot of parts listed that do not work for this particular application.
I always go OEM or better. This isn't a honda civic (not that I don't like civics)
Balla cars need oem parts!
I just dropped $800 on OEM parts for my car and it's worth no where near what I'll be spending on an ISF
Unfortunately, the 250/350 hubs are not the same as the F. Lexus put a wider front track on the F with wider, heavier duty hubs. I've seen the Timken listed, but I believe we do not know if they actually fit the F or just the other 2IS.
Lexus OEM will always work too, Right part # 4355053010 Left Part # 4356053010 with a price tag of $390- $430 each.
I thought I needed to replace my right front wheel bearing because of an intermittent squeak and metallic cracking sound coming from the right front... After removing the wheel and brake rotor, and cleaning the hub assembly, the sound has not returned. (also checked - zero endplay in hub bearing)
