p0175,p0172,p1170 codes
PPEHeaders
Sponsor
Trader Score: (4)
Quote:
Originally Posted by Cronic View Post
I just bought my F two weeks ago. I am in Gilbert.
Paul do you think you could post it? I think this kind of info is useful. I will be installing your headers soon, and any potential troubleshooting info is good to know going in.
Thanks
The code is a P1170 which is for the Port Fuel Injectors. It doesn't have anything to do with the headers/exhaust. The Port Fuel Injector wires are on the other side of the computer. I am working with the installer to help diag the issue.
Ok, so far this is all Ive found , car just all of a sudden started running rough, sputtering some , CEL had these codes p0175,p0172,p1170, anyone else have this and solve it ?
Sponsor
Trader Score: (4)
Thanks
Im gonna check/ inspect 02 sen, both are like a little over a yr old, and clean MAF and reset ECM to see if this clears up......anyone else have any suggestions?
Tech Info Resource
If you have an O2 sim, check the wiring. It's more likely that than a sensor if the sensor has been working fine up to now.
So, I started to chase down what was the problem, I cleaned the air flow sensor( didn't really look dirty) and seen on the air box had been tightened too tight where the JoeZ meets it and had buckled a small bit inward and was allowing unmetered air into the motor, done a small repair , reset the ECM and went for a drive ( about 10 miles ) good so far , no CEL
Now I have the same problem with my LS460 AWD. - p0175,p0172,p1170 codes
Has your problem gone forever after this small repair ?
