Help With Understanding the ISF Engine Construction
Old 03-11-16, 06:54 PM
mmartin061
banned
mmartin061's Avatar
Default Help With Understanding the ISF Engine Construction
Since recently purchasing an ISF and reading some publications getting very technical on how it was built and having hollow camshafts and sintered rods, titanium valves, rib this and polished that. I know there are some tech heads on here for us non tech heads that may be able to bundle all of this together and exlain what some of this means for me and maybe others. From my understanding this engine was fairly revolutionary when it came out since it was coauthored with Yamaha racings engineers. Now you read some places that it is a dated design but I'd rather refuse to believe that yet. I bet not many of you knew the first gen SHO's were capable of 9000 rpm in stock form as long as you built up 3 components and I think two were the water pump and starter or alternator and something else. Compared to other V8's of that time like GM's muscle cars, the first gen CTSV as well was a 2008 model year without SC. The V8 in the Pontiac G8. Even maybe some German cars like the Audi RS4 Mercedes AMG..... etc. How "technology" wise did they compare and what kind of effort was really put forth to produce an overbuilt engine. Sorry to get long in the tooth.
Old 03-11-16, 07:52 PM
MisterSkiz
MisterSkiz's Avatar
Are you asking to compare the IS-F motor to the LSx series of GM Motors?
LSx motors are the dumb simple, reliable motors, single camshaft in middle, same cam profile all the way through the RPM Band. GM had some weak spots in some of the motors. The valve springs were crap in some of them, the have oil starvation issues in some version of the LSx motors, which lead to spun bearings.
Due to the design of the LSx motor, the torque curve is more of a straight line, dropping off around ~5800 rpm if my memory serves me right.
The IS-F motor was basically built to be a racing motor. It has been designed to have less rotating mass, as well as small oil cooler, scavenger oil pumps to pull returning oil from the heads back into the oil sump. Most Toyota stuff is overengineered as they are very conservative.
Take a look at the RC-F motor to see what they improved from the IS-F motor. The RC-F motor literally was pulled from the IS-F race car and put into a street car...great motors.
Old 03-11-16, 07:55 PM
mmartin061
banned
mmartin061's Avatar
Yes that's what they said about the RCF motor. How about against aome of the German competitors? It's jus nice to have a simple understanding. Appreciate the response.
Old 03-11-16, 08:49 PM
tas02
tas02's Avatar
Take a look at the insides of our V8's in "Geoff's swap thread" in the "Build Threads" subforum. There's pics showing a beefy, deep-skirted block with 6-bolt main bearing journals. And notice the fully machined crank counterweights & rods. In the shots of the cyl heads, check out the phasers on both intake & exhaust cams, not to mention the scavenge pumps.
Talk about overbuilt.
Old 03-11-16, 10:05 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
To the OP. You may be interested in reading the attached.
There are more covering other aspects of the car.
Lou
File Type: pdf
Old 03-22-16, 08:55 AM
mmartin061
banned
mmartin061's Avatar
Thanks for helping out with the literature as well much appreciated
Old 03-22-16, 01:33 PM
2URGSE
2URGSE's Avatar
The hollow camshafts and sodium filled exhaust valves are nothing new, they have been out there for quite sometime. The Subaru WRX STi had these features.
The titanium intake valves are surely a nice touch.
The lubrication system seems to be pretty advanced with the secondary pump.
Old 03-22-16, 02:08 PM
SubOrbital
SubOrbital's Avatar
Didn't even realize we have magnesium valve covers.
Old 03-23-16, 12:53 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Sodium filled exhaust valves? Where did you see that? I've never seen them on anything without a turbocharger on the engine. I wouldn't bother with it myself, it's not cost effective at all for an NA engine with specific output this low. 85 hp per liter is even less than the 2GR-FSE in the IS350. I have always seen that as a disappointment.
This is not even close to a race engine. Stroke is way too long which limits safe redline pretty significantly, and at the very least the cam profiles are totally street oriented. it's why the engine can't breathe above 6800 rpm and torque drops like a rock as redline is exceeded. Without different cams, I see no advantage at all to raising the redline on this configuration. Last, but not least, while the lubrication system is better than many wet sump designs, it is still a wet sump. No proper racing engine uses a wet sump unless the rules for the class prohibit a dry sump.
I am also wondering if our engines will become the sought after design since we have bigger rod bearing journals than the RC F version which means our cranks are stronger. Yes, there is more fluid drag because the pins are larger and the linear speed (shear) of the bearing is higher which also very minorly impacts redline vs. service life, but the crank being stronger means less flex, less issues with torsional vibration, and ultimately more power before disaster strikes.
It would still be an interesting experiment to see if the top end pieces will fit our bottom end pieces and run with the RC F ECM.
Old 03-23-16, 01:45 PM
tas02
tas02's Avatar
Lobux, is either version of the 2UR used anywhere in the world in any racing series?
Old 03-23-16, 02:15 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Not on a significant scale. That's a lot of the problem. More cars on track means more development. More development means better aftermarket support. If you look at the small block Chevy platform, there are so many options it is staggering, simply because that engine has been used in all kinds of competition. Parts are cheap. Good tuning advice is easy to get. Millions upon millions of man-hour have been spent on making that engine better, faster, cheaper. And it really is.
Old 03-23-16, 02:44 PM
JaponesV8
JaponesV8's Avatar
Then why does GM have such a ***** reputation for reliability? My friend just blew up his 2009 Z06 motor with 33k miles. Said it was because a bad tune?
I hear they make great engines, but I've never heard of a reliable GM product.
Old 03-23-16, 02:49 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I didn't say factory engines, I said platform. The factory still hasn't decided they want to build quality products. Once you get them, you can make them into quality products, and pretty cheaply compared to other options.
Old 03-23-16, 05:16 PM
RyanMcZ06
RyanMcZ06's Avatar
Hi. 2008 Z06 btw . When a non stock tune puts you in knock retard hell and causes the disintegration of a piston, it's hardly the manufacturers fault.
Old 03-23-16, 07:18 PM
juanmedina
juanmedina's Avatar
What about the new C7 Z06 that blew up with only a few miles or the ones that pull timing because of improper cooling....
Now that the ECU has been cracked time will tell how strong the IS-F engine is. We don't really need this engine to rev to the moon, 6800rpm seems acceptable to me.... We seem to forget that we have a transmission that can shift in 100ms
Quick Reply: Help With Understanding the ISF Engine Construction
