What style of lug nut is recommended with aftermarket wheels on the ISF ?
Was going to be getting wheels very soon and really wanted to make sure I have correct lugs. I have been told that I need " ET" lugs ( extended thread ) and I have also ben told that I need the " cone seat" lugs. When I look online it looks like the ET lug style is just the conical seat type but reaches a little further. I am concerned that using an inappropriate lug will cause vibration .
Any suggestions or info would be greatly appreciated. What type of lugs are you using on the F? I have seen people buy really high end lugs. I never even thought of it. I would just use what they recommended at Discount tire in the past. I just figure that I really want to pay attention to the details with this set up.
PS please excuse my ignorance on this topic if this is super obvious
Thanks so much for your help in advance guys
As mentioned above you'll want to make sure you get 12x1.5 for thread pitch.
All aftermarket wheels I know require the conical lugs. As for the ET, I'm not familiar with them but I assume they'd be for people with extended studs. I see no reason you would need them unless your new wheels have really deep holes and normal lugs would be too sunken...that's usually not the case though.
I have seen people buy high end lugs for years and never even thought about it.
I've always been a fan of Rays lugs..theyre forged and are super light as well as durable. Dare I say I used an impact on them quite a few times :/
As far as being more secure I can't see that being the case. Say you get a full 8 or so threads on the lug.. if you had an et style it'd still be 8 threads. Once it's snug against the wheel it's done.. an extended lug would just stick out further. Or I could be missing something completely. I'm by no means a lug expert. Haha.
Tech Info Resource
Thanks for the response guys. I was told that it actually might vary by the wheel. I mentioned the ET style because the guys at discount tire said that would be the best make sure the wheel is as secure as possible, but most say the conical seat type is fine.
I've never seen an aftermarket wheel with anything but conical seat lugs. ET is recommended for safety. You track your car. You would be foolish to run anything else. Also be certain you get hubcentric rings for your new wheels. They are critically important for track duty.
HRE FF15 . Flow Formed line from HRE. They should be pretty high quality wheels. HRE is on another level when it comes to quality and quality certifications.
19x9 et40 255/35/19 and rear 19x11 295/30/19 et55 wrapped in Yokohama Advan Neova AD08R Wheels weight are 21lbs front and 23lbs rear. This should help keep me under oem wheel weights or at least even but with a ton more grip. I decided to order the wheels with custom Anthracite finish. I decided against black wheels. Seems like you lose a lot of the detail of the wheel in the lack of contrast . They said the 19x11 et55 was really for the RCF but they test fit the wheel on an ISF they had and it cleared !!
You are 100% correct. I knew a company like HRE would supply hub rings, but I called today and found out that they will even be supplying the lugs I need to for the wheels !! I was pretty happy about that. You are right about the lugs being 12x1.5 conical too. I had no clue about any of this "lug stuff". Just always had Discount tire give me what they said was best or safest. Really never had exposure to the technical side of lugs. Lady on the phone at HRE said their lugs are light weight
Hre are good wheels just ask what the center bore is if hub centric rings are needed buy some metal ones not the plastic ones I own a tire shop and have had multiple people come back from vibration problems with plastic rings after we changed them to metal all was good ...☝ those are some nice lug Nuts
-R
I found them on Amazon. Kics Project R26 12x1.5 ??? Sound right. I am tempted to order a set just in case. I would gladly drop $150 to avoid drama or vibration . I tried googling HRE hub rings and nothing comes up other than they are hub centric. Not sure if that's the case the the Flow Formed line since they are "entry level" HRE wheels. I will check it out.
