Asphalt overspray on the F mostly saved with detail
Old 08-29-15, 11:00 PM
FIGS
The Maker
FIGS's Avatar
Default Asphalt overspray on the F mostly saved with detail
Well today we got a nice surprise at the shop when I came out to find the parking lot being asphalt coated (with no notice) and the spray trucks pressure hose burst approximately 5 feet in front of our F. The hot coating got on our paint from tail lights to hood even a spot or two on the new BC forged wheels. We had swapped out the rear wheels to the 18" kosei's while we test alignment changes with the 265 TOYO setup so thankfully they were not installed. The koseis may not be fixable as the paint reducer we had to use to get the coating off also had an impact on the clear of these wheels. I actually came out to find (the dude pictured) trying to rub off the asphalt with a paper towel and some water. In any case, the local detail shop was able to act fast and get as much off as possible. Still a few lingering pieces on the tail lights and bumper crevices.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 08-30-15, 02:13 AM
Sylvan
Sylvan's Avatar
�� that layer of road film likely helped keeping it from sticking a bit. Did the paving company pay for the detail at least?
Old 08-30-15, 03:16 AM
Lmood
Lmood's Avatar
Omg I would be highly pissed off. I have heard in the past that gojo, the cream not the with pumice obviously, works well with breaking down and removing the asphalt.
Old 08-30-15, 04:57 AM
Justind27
Justind27's Avatar
they sell jugs of goof off, might give it a try!
Old 08-30-15, 09:54 PM
Sylvan
Sylvan's Avatar
I have heard WD40 works but I haven't had much luck with it, my wife has some oil on her rocker panels and I spray it with WD40 and let it soak for 15min before I wash it. It's getting better but it's not the answer that's for sure.
Old 08-30-15, 10:35 PM
shyguyF
shyguyF's Avatar
Gasoline take the asphalt off easily but you have to get your F waxed after that.
Old 08-31-15, 02:12 AM
kauaian
kauaian's Avatar
Kerosine also breaks it down damn near immediately but I don't know how it will affect the paint.
Old 08-31-15, 07:22 AM
streetx
streetx's Avatar
Try stoners tarminator
Old 08-31-15, 02:08 PM
Zelfiris
Zelfiris's Avatar
is the photo in the OP the amount of asphalt left after the detail?
Old 08-31-15, 08:47 PM
FIGS
The Maker
FIGS's Avatar
wd40 was tried, kerosene and diesel fuel; are too harsh on the paint. Paint reducer was the last of 5 compounds used. The guys were attaching the side of the building they botched today and were really unable to get it off the brick mortar with a pressure washer and wire brushes.
Last pics below were after detail, but there are still lots of spots in the tight areas.
__________________
Old 08-31-15, 08:50 PM
Bigjon3475
Bigjon3475's Avatar
Heavy duty degreaser with a warm water pressure washer...
You'll need to rewax after...
Where do I send my invoice to? :-)
Old 09-01-15, 03:52 PM
otbevo
otbevo's Avatar
Jeez... whatever you spend to make it right, I hope the paving company is going to take care of you. Good luck!
Old 09-03-15, 11:53 AM
SatComm302
SatComm302's Avatar
I hate that this happened to you. I would take your car to the owner of the asphalt company and have them take care of removing the contaminate from your paint. That's why they have insurance. It may not have been their fault that the hose failed, but they are responsible for the consequences that came from it.
Good luck and keep us updated.
Abernoots
Automotive Care & Detailing
05-15-18 02:03 PM
dannyboy26
03-03-14 07:32 PM
G-SharK
01-17-14 03:48 PM
Flahmingo
04-01-10 07:35 AM
niteLEX
07-24-09 03:52 AM
Quick Reply: Asphalt overspray on the F mostly saved with detail
