Alignment + Springs question
Sorry if this has been brought up numerous times but I read through all of the alignment and FIGS thread with the inner tire wear problem but I am still a tad confused on what I need to do to fix this, probably just need some confirmation. My last set of tires popped because of the inner tire wear. I was told by the tire guys that I needed an alignment bad so I got my mechanic to do an alignment after I installed my new tires 245/35 and 275/30 combo. After the alignment I pull to the right pretty hard and my steering wheel leans to the right also. I've attached the alignment specs
From what I read, FIGS LCA bushing would address this? I am also considering getting swift springs to drop the front, the wheel gap is getting to me.. but probably be best to address this before moving on to springs?
I have the same issue. Just installed tires 2k ago had the car aligned twice and the car pulls to the right with the right paddle slightly lower on the steering wheel than the left paddle. I took it back and they adjusted the tie rods to center the wheel. I had them do it and I test drove it . It was MUCH better but still pulled to the right. I am HUGE so I had them even align the car with me in the drivers seat. Going to have them adjust the steering wheel again when I go back. I love how they always like to blame it on the tires.
Tech Info Resource
Also, if you are going to put in LCA bushings, do it before moving anything. It's possible the slop on the bushing install will fix some/all of the problem, and the bushings will definitely be an improvement no matter how you slice it.
Are you guys noticing your steering wheel is turned to the right slightly.
Car drives straight as an arrow now, even with the slightly irregular tire wear on the OEM tires from the factory alignment.
My car drifted slightly to the right when I purchased it with 7032 miles on the clock. Pretty much immediately lowered the front with Swifts, installed the Figs LCA bushings, and aligned it, including the 'Lance' zero (or close to it) toe.
Your front subframe needs to move a little bit to the right to even out your camber issue. I may do amazing things for pull as well, but will require full alignment again because repositioning will impact all three numbers - camber, caster, and toe. It's not a small task so don't expect your shop to be excited about doing it.
