Anyone else with this? (front bumper cover gap)
Old 03-07-15, 09:44 PM
digger08
digger08's Avatar
Originally Posted by Sean
So I got my brackets today. I specifically requested those that match the 2011+ LED headlights but was still sent those that mount to the 2008-2010 headlights. Is there a separate part# for the newer brackets? All I see is 5211553042 no matter what year IS-F I select. I'm not sure how I can explain this when ordering to where I can guarantee getting the correct ones.
Or, are the headlights that Sewell sends out mounted differently than those that actually come on the 2011-2014 ISFs (ie. the brackets are the same 2008-2014)?
That is the right part number for +2011 and up
The Sewell lights did not include the bumper clips, you modify your old ones
Digger08
Old 03-08-15, 08:56 AM
Sean
Sean's Avatar
Digger08
I know Sewell didn't include the brackets. The problem is the part number is the same that fits the old lights also. My old brackets, which I modified, flex downwards a little bit on the side that doesn't attach to the lights since the screw doesn't line up and it seems this is what is creating the gap.
I'd like to get the brackets that are actually made to fit the 2011+ lights rather than trying to work with my old ones or modifying a new set. I don't want to go through the trouble of removing the bumper and lights again without being pretty sure what I am doing will fix the problem and the proper brackets seems to be the best solution.
I don't understand how the bracket can be the same for all years unless the lights that are on the 2011+ cars are different than the lights Sewell provided and actually mount properly to the old brackets.
Old 03-08-15, 06:28 PM
TISF
TISF's Avatar
Hmmm thats weird thats the part i ordered as well the other side is 5211653042 and thats what it says on Lexussouthernatlanta parts too so maybe you just have to modify it which doesn't make sense because alot of people dont have that problem i might just try and ordering it again il check with my local dealership first and if not il do it some other time hopefully this week and il post pictures up
Old 03-08-15, 06:30 PM
TISF
TISF's Avatar
Digger08
Can you explain these bumper clips
Old 03-27-15, 02:42 AM
specie
specie's Avatar
Any updates with this? I find the gap so annoying.
Old 03-27-15, 08:55 PM
Sean
Sean's Avatar
I'm still sort of trying to find new brackets. It seems like those that fit the 2008-2010 lights are what you get no matter what year IS-F you are ordering for. If I can't find them I'll work with my old ones that are on the car now and find a way to prevent them from flexing as much as they do.
Old 03-28-15, 03:37 PM
hahahaf
hahahaf's Avatar
I had this issue after the retrofit
I've tweaked it to a point where it doesn't bother me
Getting the actual brackets that go with the lights helped a bit. I got the best results tweaking the 3 bolts that hold the light in place. There is a little play on how the light is positioned.
Old 03-29-15, 01:55 PM
Sean
Sean's Avatar
Yeah I think it would help if the lights were positioned a tiny bit lower. I really don't want to remove and refit the front bumper over and over again though weakening the tabs.
Old 03-29-15, 04:18 PM
hahahaf
hahahaf's Avatar
just for clarification.
the new bracket is an updated part
it has multiple mounting holes drilled in to it so it fits the lights before the updated led lights
so it works on both headlamps now.
Old 03-29-15, 08:03 PM
Sean
Sean's Avatar
Thanks. I actually ordered a set from Sewell before they closed the online store and still somehow got the old version - even though I described exactly what I needed. Luckily no problems returning them though. This info will be helpful in getting the right brackets
RazorBack1
11-25-18 03:14 PM
SNiiP3R
01-19-17 05:54 PM
ddiddle
12
10-02-16 05:22 PM
Smoola
IS F (2008-2014)
02-18-16 02:59 PM
VIPvPanda
04-30-11 04:28 PM
Quick Reply: Anyone else with this? (front bumper cover gap)
