Rattle with JL Sub in Trunk
Old 07-20-14, 10:35 AM
jadeboy
jadeboy's Avatar
Default Rattle with JL Sub in Trunk
After install the JL sub woofer + sound damping in the trunk, I was able to remove most of the rattles. But there is one specific part within the trunk, I have no idea how to eliminate the rattle (the paper rattles).
I have confirmed there is rattle by touching the outside of the part highlighted. It happens on both side of the car.
Old 07-20-14, 10:53 AM
RCB
RCB's Avatar
Are you highlighting the cabin vents?
If so then you are moving enough air with the subwoofers to cause the vents to try to expel it assuming it only happens with the truck closed.
Old 07-20-14, 11:09 AM
9aristo
9aristo's Avatar
on the other side of those vents, are rubber flaps. When my subwoofer was installed, i noticed the same "paper" sound flap.
I removed my bumper to remove the rubber flaps (one on each side). no more paper flapping noise. only drawback is dust can get in I think.
Old 07-20-14, 01:12 PM
chris6878
chris6878's Avatar
do you hear the rattle on the inside of the car or out when playing music?
Old 07-21-14, 10:20 AM
jadeboy
jadeboy's Avatar
Yes that's the vent. The subwoofer causes the paper to vibrates on both sides. You can easily hear it under certain songs.
Old 07-21-14, 10:22 AM
jadeboy
jadeboy's Avatar
I can definitely hear it on the outside - easily noticeable. On the inside.. I have not 100% certain yet.. will need to test.
mizike
11-30-16 09:41 PM
bighitbike
01-16-08 06:27 PM
m500
05-17-06 12:48 PM
THEWAYSC400
SC- 1st Gen (1992-2000)
10-11-02 07:56 AM
Jmai22
12-02-01 04:24 PM
Quick Reply: Rattle with JL Sub in Trunk
