air bag light
Old 06-25-14, 10:43 AM
ddcruise
ddcruise's Avatar
Unhappy air bag light
My air bag light went on, thoughts?
Old 06-25-14, 10:46 AM
tgui
tgui's Avatar
On my Subaru it turned on once in a while when a connector under the seat came loose. It might be something similar in your car?
Old 06-25-14, 10:52 AM
kauaian
kauaian's Avatar
Did you replace any bumpers recently? Maybe one of sensors were damaged some how? All the harness plugs sit pretty tight so it's unlikely one of them came loose unless it was unplugged and not seated correctly when replaced. But you never know anything happen...
Old 06-25-14, 10:59 AM
ddcruise
ddcruise's Avatar
the dealer asked if i was in a accident and since i was not they are still looking
Old 06-25-14, 11:03 AM
LexusNN
LexusNN's Avatar
check the connections, mine came on and I messed with the one under the seat and one for the knee airbag. then it went off
Old 06-25-14, 11:42 AM
I8ABMR
I8ABMR's Avatar
I would move the seats all the way forward and up and then check the connection for the harness below the seat. Do you ride with people in the back. Maybe someone with some big feet messed with the connection or an object under the seat did it. Not sure
Old 06-25-14, 01:46 PM
NotnFsport
NotnFsport's Avatar
What year is your F? I had an airbag light come on and it ended up being a fault harness under neath the dash area. It was covered under warranty . I cant remeber if it was a recall or tsb.
Old 06-25-14, 07:21 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,079 Likes on 2,472 Posts
Neither. TIS does not show any recall or LSB for anything SRS related.
Old 06-26-14, 03:30 AM
BluStreak1
BluStreak1's Avatar
My light came on about a week ago...took it to my friend to have it read...Fr driver side knee airbag. Probably a loose connection, still haven't took it in to the dealer yet...
Old 06-26-14, 05:33 AM
NotnFsport
NotnFsport's Avatar
I just looked ut up. Its a lsb addressing this issue. It affected mostly 250s and 350s but my ISF was also affected. Dealer replaced mine under warranty.L-SB-0167-08. Theres was a faulty harness going to the drivers knee squib.
Old 06-26-14, 07:50 AM
ddcruise
ddcruise's Avatar
i have a 2008
Old 06-26-14, 12:13 PM
imp0rted1
imp0rted1's Avatar
had the same problem but was out of warranty by the time it was addressed. dealer quoted something like $600 for the part (08 IS-F)
Old 06-26-14, 02:54 PM
zazzn
zazzn's Avatar
very interesting, I have been having this issue on and off for months.
Old 06-26-14, 03:13 PM
I8ABMR
I8ABMR's Avatar
at least we know there is a fix for it
Old 06-27-14, 11:03 AM
ddcruise
ddcruise's Avatar
dealer had my car for 5 days and counting
Quick Reply: air bag light
