how to put a cf vent on our hood ?
Old 02-25-14, 05:32 PM
yishin
yishin's Avatar
Default how to put a cf vent on our hood ?
i know there r 3d whtever vent that cost too much
but is there anything more affordable vent kit that we can add to our hood ?
not the seibon ts 2 hood.
? its for isf
Old 02-25-14, 06:28 PM
G9N
G9N's Avatar
I've done some research and the cheaper ones are not worth the cost of the install. I love Blitz's car and I don't want to fully replicate it only slightly copy it. However, when you vent your hood it's imperative to have rain catching or specialized run offs. Otherwise you will compromise electronics that could cost you much more than paying for expensive vents. Also, the cost to install them is going to be the same so why not get the part that you know will last.
Old 02-25-14, 06:39 PM
yishin
yishin's Avatar
What is the best way to pull out engine bay hot air ? Only vent ?
Old 02-25-14, 07:15 PM
G9N
G9N's Avatar
Cowl style hoods are the best way to remove hot engine air.
Old 02-25-14, 10:16 PM
Rossi
Rossi's Avatar
? its for isf
The Seibon TSII is the best way go.......About $700 + about $400 if you paint it.
https://www.clublexus.com/forums/is-...d-for-isf.html
I believe the vents Blitz used are from BMW costing around $1200 plus you pay the body shop
to install them.
Old 02-26-14, 03:12 AM
G9N
G9N's Avatar
Why are you so concerned with venting hot engine air?
Old 02-26-14, 02:29 PM
yishin
yishin's Avatar
I wanna get a open box air intake so if drop some hot aair from engine it may reduce the heat soak?
Old 02-26-14, 05:05 PM
airvtec
airvtec's Avatar
OP: I got your message, but my vents are from 3D Design, which are quite costly. I've searched the internet for awhile and just couldn't find vents that are functional and looked good. I first installed these vents made for an older Suburu STi, but it looked bad. I finally decised to go with 3D Design. They are functional and look great. They also come with removable rain catch. If you don't want to spend that much I say go for the Seibon hood.
Old 02-27-14, 01:29 AM
ISF4life
ISF4life's Avatar
I have what airvtec has , so listen to us and do it right lolz
Old 02-27-14, 10:39 AM
CalitriSC
CalitriSC's Avatar
Or don't cut up your stock hood lol.
Rokas
20
08-02-18 04:17 AM
Deathbarel
SC- 1st Gen (1992-2000)
02-16-17 09:01 AM
yishin
IS F (2008-2014)
04-11-14 05:03 PM
4everkidd
IS F (2008-2014)
23
04-10-13 08:23 AM
chanhichan
08-22-01 10:56 AM
Quick Reply: how to put a cf vent on our hood ?
