Rotor Removal Tip
Old 02-17-14, 06:41 PM
UCrazyKid
UCrazyKid's Avatar
Default Rotor Removal Tip
I did a front brake job on the ISF today. All OEM parts from Sewell (thanks guys) pads, shims, caliper pins, springs and rotors.
What should have taken 1 1/2 hours took 3 because I didn't figure this out until the end.
On the rotors between the studs are two threaded holes. When I saw them I thought "Oh, they are for mounting screws". Wrong.
After removing my wheels and saw no screws in the old rotors I thought to myself "The last mechanic didn't use the screws!?" I was wrong... again.
After 30 min on EACH side of PB blaster, rubber mallet'ing, hammer smashing, blow torching, swearing, bruised knuckles and over all frustration...
I occured to me that maybe... If I threaded a bolt into the holes it would press OFF the old rotor. BINGO!
I found a M8 x 2 x 1.25 pitch bolt, threaded it in an PRESTO! the rotor was off in 15 seconds.
Duh.... I can't let this go. I feel so stupid. I want my 1 1/2 hours back.
ANYWAY it should be known that to do rotors have a M8x(doesn't matter length)x1.25 thread pitch bolt. And the job is easy.
Old 02-17-14, 06:47 PM
J2K
J2K's Avatar
I'm not trying to throw salt in the wound or anything, but Caymandive mentions this in the first post of his DIY rotor replacement thread.
https://www.clublexus.com/forums/is-...ke-rotors.html
Glad everything turned out well for you in the end though.
Old 02-17-14, 06:57 PM
chrisp1
chrisp1's Avatar
Originally Posted by J2K
I'm not trying to through salt in the wound or anything, but Caymandive mentions this in the first post of his DIY rotor replacement thread.
insert salt here! lol
Old 02-17-14, 07:01 PM
UCrazyKid
UCrazyKid's Avatar
Learning it the hard way... I will never forget it. LOL
I had only found the ultimate brake thread and the pads only thread. Guess I needed to dig deeper.
Let me be a reminder to all... SEARCH!
Old 02-17-14, 08:15 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Actually I've seen this on Toyotas since my first GTS Corolla in 1988. They've always done this with their rotors.
FWIW, I did a four jackstand wheels off car wash today after the salt and sand of the last month in Atlanta. While I was at it, I swapped out the front pads. My rotors were loose on the hubs. I've never needed the bolts to get the rotors off. Maybe it's because I know the holes are there and I have the bolts in my tool box...
Old 02-17-14, 08:40 PM
itsmike177
itsmike177's Avatar
The caliper bridge bolt screw will fit the 2 holes in the rotor to make things easier.
Old 02-17-14, 09:35 PM
phm14
phm14's Avatar
Reminds me of when I discovered that. Hadn't thought about that in decades...it was pre-internet
Old 02-18-14, 09:52 AM
ljdsong
ljdsong's Avatar
thanks for the tips, any info how to change the studs easier , im planning to put 20mm H&R spacers on my f with the longer studs.
Old 02-18-14, 11:50 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
OP i went through the same thing 2 days ago with replacing my rotors... You should see the rubber mallet i bought.. Well there's a nice chunk out of it where i beat the rotor to death.. then realizing i should use the screws... such a headache... i knew we needed screws just didn't know the rotor had a death grip on the car.
After a few turns they popped right off...
Old 02-18-14, 03:56 PM
fasttexasz
fasttexasz's Avatar
Awesome and best way to learn!!! Pretty sure everyone has that Homer Simpson moment in there lives. Doh!!!
Old 02-18-14, 06:06 PM
UCrazyKid
UCrazyKid's Avatar
That's easy (one came out in my process). They are just pressed in. Get the rotor off, heat the hub around the base of the stud (try to avoid the stud) and hit them on the end with a hammer, they should back out. A lubricant might help too, non framable, like PB Blaster.
AA
Old 02-18-14, 10:11 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Hitting anything attached to the hub with a hammer is a bad idea if you want your wheel bearings to last. Wheel studs can be pressed out very easily, and there are even inexpensive tools to do this. This guy even did a DIY for the Evo board.
Old 02-19-14, 01:58 AM
tmf2004
tmf2004's Avatar
hope I didn't do any damage. I was hitting it with a hammer and rubber mallet and eventually used to the two screws to loosen the rotor off.
the was a lot of force behind the hits and turned the rotor a few inches and tried to hit evenly across the backside . you got me nervous now
audphile1
07-08-18 05:03 PM
dc893
03-18-13 11:36 AM
VJZ
Suspension and Brakes
04-09-09 10:34 PM
ta1972
10-09-07 11:55 PM
tmorales
04-05-04 10:23 AM
Quick Reply: Rotor Removal Tip
