Will these rims fit?
Yokohama Advan RZ
19x9.5
Offset: ET25
PCD: 114.3
Bore size: 73.1
If the will fit would I need any sort of adaptor ring to fit the ISF?
Any idea if they'll look ok on stock ride height?
19x9.5
Offset: ET25
PCD: 114.3
Bore size: 73.1
I don't have any experience with fitting a wheel with these specs on an F, but one resource I use when messing around with wheel options is fitmywheels.com to see how they compare to stock. Unfortunately, they don't show how it would line up with the fender, but it's good to get a visual on the difference.
You'll need a 73.1 to 60.1 hub ring. The specs are pretty aggressive if you are planning on running the square setup. Just as a reference, I'm running 9.5+42 in the rear with zero fender work. Any wider and I would have to shave. As for the front, you'll definitely have to roll.
Thanks for the feedback guys,
I have these lying around from my previous car and thought I might try and see if they'll fit.
I'm probably best off trying to sell them and getting some nice Volks instead
