Jacking Problem
Old 06-03-13, 08:48 AM
whaler96
whaler96's Avatar
Default Jacking Problem
Hello everyone, this is my first time posting, I purchased a 2011 in October and have found this site to be incredibly helpful. In fact, I have always found answers to all my questions using the search button, until now! I was installing my summer tires on the weekend and on the final tire (drivers front) I had the pinch weld fold over while jacking it up. Has this happened to anyone before? How do I go about fixing it, is a something I can claim on warranty? I have jacked plenty of cars before including this one and have never seen this happen. Any suggestions would be appreciated. Thanks again for all the great information.
Old 06-03-13, 09:30 AM
streetx
streetx's Avatar
Happens to everyone
i dont think you will be able to claim this on warranty
Old 06-03-13, 10:12 AM
obby
obby's Avatar
normal.. mind is totally flat on all 4 corner.. lol.. you can try prying it back to normal and go order the Figs jacking point tool.
Old 06-03-13, 10:24 AM
MisterSkiz
MisterSkiz's Avatar
I have problems jacking sometime, usually I imagine the girl next door coming over to thank me for fixing her laptop...oh wait a min.
Yeah, it has happened on all of my cars when I use a flat jack. They do sell tools that are shaped with a notch to avoid the issue, but I wouldn't worry about it.
Old 06-03-13, 10:25 AM
JT2MA71
JT2MA71's Avatar
Received 1,513 Likes on 656 Posts
I always use a block of wood in between the jack and the lifting point. Or I just lift the whole front end or back using the crossmember or diff. So far, no bends on any of the cars I've owned or Own now.
Old 06-03-13, 10:32 AM
FD3SISF
FD3SISF's Avatar
I just use the diff or front crossmember also to lift my car.
Old 06-03-13, 11:28 AM
vbb
vbb's Avatar
Okay, so clearly I'm not the only one on here who is still stuck in 9th grade, because I definitely chuckled at the thread title.
Old 06-03-13, 11:49 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
I folded one on my first Supra in 1994. Never since. If it even thinks of bending, I straighten it with this:
I also use wood on the jack, but I generally lift on the front cross member and put the car down on jack stands at each of the OEM jack points to avoid side loading the body seams.
Old 06-03-13, 12:31 PM
digger08
digger08's Avatar
Hockey puck with a slit in the center works great as well...but being from Canada we have lots of Hockey pucks!
Like this....example only
Digger08
Old 06-03-13, 12:40 PM
whaler96
whaler96's Avatar
Thanks for the replys everyone, I have no shortage of hockey pucks around so i guess i will make something like digger08 suggested. My floor jack has a large rubber pad on it, so i never thought this would be a problem.
Old 06-03-13, 01:41 PM
GriMan
GriMan's Avatar
Same here. Can't really do anything about. idk why it was setup like that.
Old 06-03-13, 01:48 PM
psixtc
psixtc's Avatar
I tweaked the pinch weld the first time I jacked my F up and straightened it out with a crescent wrench, just like lobux showed.
Luckily FIGS recently came out with a jack jaw for the pinch weld a couple weeks later and I picked one up. It's worked great the half a dozen times I've used it.
http://shopfigs.com/v1/index.php?rou...product_id=188
Old 06-03-13, 03:46 PM
JT2MA71
JT2MA71's Avatar
I did too but I resisted I could have come up with quite a few tips.
Old 06-09-13, 04:29 PM
DCoolBeans
DCoolBeans's Avatar
Digger08
Does that metal lip touch the puck or the puck is beveled out so the sides touch the body w/o the lip touching?
Old 06-09-13, 04:55 PM
CarbonISF
CarbonISF's Avatar
There are some good ideas out there:
The creative pucker:
or
The double pucker:
This should be able to support around the pinch weld so there isn't any chance of bending.
mikemu30
RX - 4th Gen (2016-2022)
10-17-17 07:33 PM
tna
IS F (2008-2014)
15
11-16-15 12:30 PM
PghLex
12-15-11 09:17 AM
danefx
10-09-07 08:46 PM
Quick Reply: Jacking Problem
