Hood lift support struts..blew out
Old 03-27-13, 05:22 PM
zapa
zapa's Avatar
Originally Posted by fasttexasz
I tried sewell and they were not cheaper than this place and they are factory original supports. I replaced both of mine bout a month ago and my car has 80,000miles.
http://www.lexuspartsnow.com/Page_Pr...ponentsIndex=6
does your hood still flap up and down like you said it did when?
Old 03-27-13, 05:38 PM
fasttexasz
fasttexasz's Avatar
Not as severe but still a litte bit but that's probably just the crappy roads around southern Virginia.
Old 03-27-13, 05:54 PM
zapa
zapa's Avatar
you can say that for sure. Roads in va suck
Old 03-27-13, 07:11 PM
Just F Me
Just F Me's Avatar
I heard the F Sport hood struts are lighter...jk
Old 03-27-13, 07:23 PM
digger08
digger08's Avatar
That's the first thing you've said that makes sense..lol
..maybe I'll fill mine back up with helium?
Digger08
Old 03-27-13, 08:33 PM
Just F Me
Just F Me's Avatar
Every now and then something intelligent comes out. It's rare...but it happens.
Old 03-27-13, 10:17 PM
SeanGTS
SeanGTS's Avatar
Thanks to you...I just checked my ECP extended warranty which is 8 years/ 200K (kilometers) on my car and low and behold my hood shocks are covered under Body Hardware.
I did not even think this would be covered, as it seemed to be a wear and tear item.
deemed as ......"Hood and Hatch supports" and listed under Body Hardware.
BTW this is a Canadian Warranty, yours may differ.
Thanks Sean...problem solved.
Digger08
My first helpful post on here.
Old 03-28-13, 07:40 AM
digger08
digger08's Avatar
I'm happy to report.......
I just returned from the dealer....no problems, no questions asked...all covered under warranty, and they replace both sides, not just the faulty support side.
Digger08
Old 03-28-13, 08:36 AM
Just F Me
Just F Me's Avatar
You're still under warranty? Was there a doubt they weren't going to replace it? Dealers pretty much want to do as much warranty work as possible so they get paid by Lexus. And they just say "we're taking care of the customer"
Old 03-28-13, 12:12 PM
digger08
digger08's Avatar
Its a Lexus Extra Care Protection (ECP) extended warranty, that's not quite like the new car one.
There is lots of stipulations, wear and tear clauses, that exempt Lexus liability....so you have to read the fine print carefully.
They even have different coverages on wheel bearings, for rear wheel and front wheel drive cars...so its not quite a slam dunk.
As an example my old OEM exhaust tip fell off, due to the bad tack welds...they would not cover this under warranty. My recent serpentine tensioner failure was also not covered, and there is even a TSB on it........Lexus Canada has some differences over the USA as well.
Digger08
Old 03-28-13, 12:57 PM
Just F Me
Just F Me's Avatar
I see...thought it was factory warranty...I didn't see that you were from Canada ey.
Old 02-16-17, 01:08 PM
F_Throttle
F_Throttle's Avatar
Sorry for the bump.. Anyone got a recommendation on replacement shocks for both the hood and trunk?
Old 02-16-17, 03:45 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,081 Likes on 2,473 Posts
Got my replacements from an eBay vendor - liftsupports. Both trunk and hood. Fit perfectly. My hood struts died during the valve lash adjustment. I had to clamp the rod with vise grips to hold the hood open while I was waiting for the new struts.
Old 02-16-17, 04:39 PM
Joker4096
Joker4096's Avatar
I bought an OEM set off of eBay.
Old 02-16-17, 07:06 PM
PatrickISF
PatrickISF's Avatar
Do you have the specific part number from this vendor? I looked and I didn't see any from that seller for the ISF. Mine blew out after the dealership left it up doing the valley plate leak.
NM - I think I found it - was this the one: http://www.ebay.com/itm/Qty-2-Stabil...item4d487fb216
Quick Reply: Hood lift support struts..blew out
