RPF01 in 19"
Old 01-12-13, 11:21 PM
ilv1004s
ilv1004s's Avatar
Default RPF01 in 19"
hey guys cant seem to find the answer
RPF1
Front: 19 x 9.5 +42
Rear: 19 x 10 +22
i know the front is fine
but the rear is a bit of a hard 1
will the rear be ok?
lowered on KW coilovers
Old 01-12-13, 11:51 PM
CalitriSC
CalitriSC's Avatar
That rear is not going to fit very well unless you have some stretch, pulled fenders and camber. This is 19x10 +33 and my rear fenders are rolled flat with a tiny pull. Your specs would stick out another 11mm. If I added a 10mm spacer it would rub like crazy.
Old 01-12-13, 11:57 PM
ilv1004s
ilv1004s's Avatar
so what about if i fit the 9.5 +42 in the rears
Old 01-12-13, 11:58 PM
ShadowISF
ShadowISF's Avatar
You're gonna have to do a lot of fender work to fit those rears.
Old 01-13-13, 12:16 AM
CalitriSC
CalitriSC's Avatar
9.5 +42 rear would fit pretty easy.
Old 01-13-13, 04:37 AM
ilv1004s
ilv1004s's Avatar
what would be a good size to fit the rears
X10 +30?
Old 01-13-13, 05:21 AM
vbb
vbb's Avatar
X10 +30?
To give you a general idea of fitment, I'm running a 19x9.5 +29 in the rear. I had to roll the rear fenders to prevent rubbing over the harshest bumps. The fronts don't even come close to rubbing at 19x8.5 +38. This is all on stock ride height and stock tire sizes.
Old 01-13-13, 06:05 AM
Nameless1
Nameless1's Avatar
19x10.5 +30 in the rear will fit like this. Granted the pictures shows the rears are not dropped, tires are 275/30/19, 0 camber adjustment, and fenders are not rolled yet. Note the lines on the tires. That's where the fenders rub against them. That will give you a reference point of where your offset should be. Based on my experience, I would recommend somewhere around +40 range for offset.
Ltaboso
IS F (2008-2014)
05-12-16 10:49 PM
Ltaboso
IS F (2008-2014)
09-26-15 12:45 AM
skpark70
Wheels, Tires & Brakes Forum
06-17-03 07:37 PM
CIA360
IS - 1st Gen (2001-2005)
02-24-02 03:32 PM
Quick Reply: RPF01 in 19"
